How low does my tank need to be?
Old Oct 23, 2006 | 09:27 PM
Stormstaff's Avatar
I just got my tunes, gotta make time to get them loaded, but I have a question.
I have 87 octane in my tank now. I'm a hair under 1/4 tank. I want to load the 93 octane tune. How low is low enough to fill up with 93 and be safe?
Thanks in advance!!!!
Old Oct 23, 2006 | 09:31 PM
scott1981's Avatar
When the fuel light comes on(or newer models odo reads "low fuel")
Old Oct 24, 2006 | 02:11 AM
Stormstaff's Avatar
Ok, thanks. Guess I'll load the 87 tune or just wait til the light comes on.
Old Oct 24, 2006 | 03:54 PM
02XLT's Avatar
To be extra safe you really should fill up with 93 and burn through that entire tank before switching to that performance tune... I want to say that I've seen Mike say this before.
-Brian
Old Oct 24, 2006 | 04:47 PM
SAJEFFC's Avatar
I have been mainly running the 87 perf tune the last several months. Just switched over to the 93 tow tune last weekend to get ready to pull a trailer to the Nascar race in 2 weeks. I was down to 1/4 tank of 87 and filled up with 93. I have had no knock issues at all so you should be fine. Good luck and you will love the premium gas tunes trust me!
Old Oct 25, 2006 | 11:07 AM
05supercrew's Avatar
I brought my tank just under 1/4 and filled up with 93 and never had a problem.
Old Oct 25, 2006 | 11:28 AM
KC-10 FE's Avatar
You can fill it up with 87 & then run the 93 tune. The engine has a knock sensor that will prevent it from destroying itself due to detonation. Now is that a smart thing to do? Absolutely not. Just wait to the low fuel warning and you'll definitely be safe. I would venture a guess that you could fill up around a 1/4 tank and be OK, if you really want to give yourself a warm fuzzy, get some octane booster. At the rate the 5.4 guzzles gas, you're talking tops a 2 day wait.
KC-10 FE out...
Old Oct 25, 2006 | 11:41 AM
I have run the 93 tune with 87 in the tank. Never heard a knock. The only time I have heard a knock was with one tank of Exxon 93. They must have made a mistake with that batch.
Old Oct 27, 2006 | 11:09 AM
tbbailey's Avatar
87 is ok
no matter what some will tell you the tuner doesnt chnage the timing enough to require high octane fuel
Old Oct 27, 2006 | 11:30 AM
MGDfan's Avatar
...hmmm... must be talkin' about the Edge.... my Xcal2 cranks in a whole lotta timin' on the 92 perf tune....
Couldn't resist - otherwise the dark side would chime in first
Yo, Bailey - where'd you pick up that load of crappola??
Cheers
Bubba
