Thanks for buying the edge!
Old Feb 6, 2007 | 10:23 AM
  #31
khendrix2374's Avatar
When I lose a street race, I post it here just the same.
Yes, I do have a 2wd. I couldnt see the point of buying a 4wd to only use it maybe 10 times. If I cant make it there with 2 wheels... I don't have any business being there.
I'm mostly just razzin' the guys with the Edge because I have an XCAL custom tuned on the dyno.. Makes a couple more ponies than the Edge does. And this thread really gets the Edge guys' undies all wadded up. LOL
Old Feb 6, 2007 | 10:58 PM
  #32
G7890's Avatar
I admit, mine is not a work truck, it's a pure pimpin highway queen. Sure it's slow, but it looks good doing it.
Old Feb 7, 2007 | 03:42 PM
  #33
chester8420's Avatar
Yeah right...
Old Feb 7, 2007 | 04:13 PM
  #34
Norm's Avatar
Originally Posted by chester8420
Yeah right...
Yes, sure does. Custom beats canned.
Old Feb 7, 2007 | 11:08 PM
  #35
Just keep telling yourself that. I always look at my IAT just to see what temp it is, when I had a leak in my radiator, I was riding down the interstate, and the edge started blinking ECT=212 and beeping. I set a warning at 4 degrees above normal. (mine rarely goes over 208*) How cool is that! I would have never known it until my mechanical guage redlined, and then it would be too late!
I can watch my IMPG (instant mpg's) and keep my truck at 18mpg. I pulled my edge out of my dash 3 times last week to pull codes on buddy's trucks. It takes about 15 seconds to get it out, and put it back in! I did 1/4 mile runs before and after I changed my spark plugs, and I did them before and after I removed my muffler. (no change in 1/4 times) I used my edge to measure off the dimensions for a new shelter, and to measure the dimensions of a pond. I also measured off my own personal 1/4 mile drag strip to the foot! I found out that my speedo is off by 6mph when I get around 95-100mph. I used it to diagnose 4 people's weak alternators. Just hook it up and it gives a digital voltage rating! I used it to diagnose a bad battery on my truck. (when I shut the truck off it went to ~9-10volts) What does your xcal do on a regular basis? Yeah, I don't race the truck. It's a truck! I do, however use the edge for a lot of other things. If you want a fast vehicle, go get a new Shelby Mustang. But if you want to come challenge me, Come ON! I'm ready and willing.
Old Feb 8, 2007 | 12:22 AM
  #36
jawjaboi's Avatar
G7890.....sweet looking truck....I like those flares!
Old Feb 8, 2007 | 08:50 AM
  #37
Norm's Avatar
That describes Edges benefits but does not dispute the FACT that a full custom tune will give you more "ponies" than a canned tune. I am glad you like your Edge, it sounds like a great product but that wasn't the point of my comment.
Just to clarify, I am running a canned tune as well with my 1715 and I know a custom tune would beat it everytime. I do not claim the 1715 is better. The XCAL was not a product when I bought my 1715.
Old Feb 8, 2007 | 10:17 AM
  #38
I don't need my XCAL to read my coolant temps.. I have electric fans to do that. When the coolant reaches about 205-207 degrees, my fan kicks on. NO thinking needed. IF that fan doesn't work and I notice the truck is running hot, I have another fan wired to a manual switch. Got that covered.
I don't care about IMPG. I most likely get about 12 MPG..lol
My IAT is lower I'm sure because my Intake kit seals off the engine compartment for lower air temps.
I don't want to read trouble codes on my friend's trucks/cars. That's what AutoZone is for.
I have a calculator to do simple math.
I doubt my speedo is off at higher speeds by much because my tires are rated at 140MPH. And they're pretty low profile. Shouldnt be much flex.
YOu caught me on one of those. My XCAL does not read the voltage of my battery. That would be nice though.
And if you don't race your truck or care about acceleration, why did you test your 1/4 mile time to see if your 18 1/4 was due to bad plugs. . Or measure off you own personal 1/4 mile.
And I would go get a new Shelby Mustang if it didnt come with a payment book thicker than the latest Harry Potter Book.
Old Feb 8, 2007 | 01:51 PM
  #39
Yeah, gotta love that extra 2.684 horsepower!
Just kidding! That means you have more than me. Enjoy it.
That isn't gonna do you crap if you spring a coolant leak, and get low on fluid. And you stock guage won't show it until your temp reaches 260* or so, and by then, you've lost enough water to be a big problem. The water temp guages on these trucks are crap. I would have never known I had a problem until it was too late, if it wasn't for the edge blinking and beeping at me.
Well, you could target any mpg you wanted if you had an edge..... but.....
Um.. How is your intake temp lower than the ambient temp? I guess I'm not following ya on this one..
Yeah, the stock guage is crap. These trucks ought to have an edge-like display already in them.
To test which mods change the performance of the vehicle. Every time somebody says "ooh, this gives the truck more power etc." I try it, and then go test it. I measured the 1/4 mile to use as a comparison to the edge's value, to see if it's accurate. And to run my friend's vehicle through. I verified the length of it with 2 other measuring devices. It's very close.
You and me both.
Old Feb 8, 2007 | 04:06 PM
  #40
G7890's Avatar
Thanks jawjaboi
Old Feb 9, 2007 | 09:39 PM
  #41
expy03's Avatar
Very good points made by all. Darn Chester, you should work up an ad for EDGE. You do stuff with that thing that I never thought of.
Just want to clarify one thing.
I have tested both stock and aftermarket using a Scanguage and the EDGE.
At cruising speed the IAT is usually within 3-4 degees on either setup. But at idle in heavy traffic, you will see temps at over 30-40 degrees above ambient temp on the stock setup; and even higher on aftermarket.
The so called cold air intakes are actually more like fresh air intakes. As the piping gets hot, it heats up the air going into the engine unless you are at highway speed and the air is moving faster through the intake.
Old Feb 10, 2007 | 01:12 AM
  #42
Yeah. When riding down the road, my IAT temps are exactly ambient. But when going really slow, or sitting still, they go up like you say.
Old Mar 13, 2007 | 04:03 PM
  #43
undeaddemon's Avatar
Thumbs up Chester... I am 'wit choo' (My Blue Heaven ref.)
Thats how I feel about it. It's not "just" a tuner, it's a great "tool"!
awesome
Old Mar 13, 2007 | 04:36 PM
  #44
PearlandAl's Avatar
can somebody get some work done already...lol jk Edge rocks and thats all there is to it.
Old Mar 13, 2007 | 08:03 PM
  #45
04 RED LARIAT's Avatar
Anything you can do, I can do better. I can do anything, better than you.
