Xcal 2 and Tires
Old Sep 16, 2006 | 07:38 PM
MZ89's Avatar
Xcal 2 and Tires
I have a 98 F150 4x4.
Im looking to get some 33" tires with a torsion bar lift. Can I get upgraded tunes to fix the speedo and other things after making the upgrade?
For some reason I remember seeing somewhere that with a 98, you had to mechanically change the speedo gearing which I dont want to do. Half the reason I got the Xcal 2 was to be able to calibrate it with the 33's, now I started to find out I might not be able to?
Can Troyer tune my Xcal 2 on my 98 4x4 to have everything work with 33"s?
Old Sep 16, 2006 | 07:46 PM
mrwake's Avatar
Talk to troyer himself. His tunes will make your truck chirp, but Im not sure about the whole speedo thing. I might be correct by saying that he can correct them to within +-3%
Old Sep 16, 2006 | 08:54 PM
MZ89's Avatar
I already have the Xcal 2. I just want the speedo adjusted if I do get 33's
Old Sep 16, 2006 | 09:04 PM
BalogUK's Avatar
with the xcal2 and some tunes, when you go to load the tune you have the option to modify driving parameters--one of which is your tire revs/mile-
but, as you mentioned- if the truck's speedo is mechanical, and not an electronic function, then modifying the tire parameter wont do anything- hence the call to Troyer Perf.
Old Sep 17, 2006 | 04:35 PM
Bartak1's Avatar
Your right, you cannot recallibrate the speedo with the Xcal. You have to get a new VSS gear, or whatever they are called.... Your dealer should be able to get you the right one and install it...
Old Sep 18, 2006 | 02:28 PM
Former Sponsor
Recalibrating the speedometer via tuning changes can be done only in the 1999 & newer F-150's - for the 1997 & 1998 models, you need to change the speedo gear in the tailshaft of the tranny, which is cheap & easy to do.
