Edge custom tune for mpg and performance
Old Aug 13, 2006 | 06:43 PM
chrisrud15's Avatar
For those of you that run the tune for performace can you post your settings
And those of you that set the tune for the best mpg can you post your settings.
I bought my Edge mostly for monitoring and really just a reflash but would like to know these settings. Im not going to run mine like a dog but sometimes i would like to get into it. Thanks for your postings
Old Aug 13, 2006 | 07:16 PM
Socal858's Avatar
for mileage (providing that the terrain you commute on is relatively flat) you can drop the normal driving shift points as low as you can so you hover in the low RPMs during normal driving. when you floor it the truck will still behave same with the aggressive high shifts
Old Aug 13, 2006 | 07:39 PM
So far, I have run only 93 octane and Level 3. My settings are:
Shift Points WOT: 1-2=5250 2-3=5250 3-4=5000 Maximum rpm=5600
Did not change normal shift points
Idle rpm: 800
Fuel at WOT: 1.8
Shift pressure: +12
Top speed: 110
Timing: plus 1.0
I have a K&N drop in and Flowmater40 SIDO
