Will the edge evo do that?
Old Jul 27, 2006 | 05:33 PM
Fordwitflows's Avatar
Soon, I will be getting a lift and bigger tires(35). I plan on getting the edge evo. Will that be able to fix my speedo/odo problem with getting bigger tires
Old Jul 27, 2006 | 05:37 PM
jre86's Avatar
If I were you I would wait a little while longer and get the new Edge Evolution II that is currently in Beta testing. It has the tunes of the first programmer, but the gauges similar to the unit for the 04+ trucks. Yes it can fix your speedo for tires and/or gears.
Old Jul 27, 2006 | 05:44 PM
the edge evo will do that or the edge evo 2? or both. The edge evo is only $300. I think Ill just stick with that if the only thing diffrent form the edge evo 2 is a diffrent face
Old Jul 27, 2006 | 06:17 PM
jre86's Avatar
I am pretty sure the Evolution I will change gear ratios, but I am not sure about tire size. Changing the gear ratio could be used in place of changing tire size with a bit of math involved.
The Evolution II stays plugged into your OBDII port and gives you guages to monitor. I have a feeling the Evolution II won't be too much more that $330 which was what the Evolution for the 04+ trucks sold for when it was released. The extra ~$30 is worth it for the guages IMHO.
http://www.edgeproducts.com/pdf/FordF-150Evolution3.pdf
Old Jul 29, 2006 | 10:47 PM
chester8420's Avatar
You won't regret getting the evolution II, and if you do, you can just take it out and leave it at home like all the other tuners, and it will do the same job as the old evolution.
