Edge @ WindowsME
Edge @ WindowsME
Ive been tring too update the edge to no good ,and I also called tech suport no help there either ,I was with hime for about a hour he finaly said I should go use another computer anyHELP PLEASE THANKS
I downloaded the driver for the Evo three times no good even when the edge is hooked up the lightning says disconnected this little square pops up--Communications Time Out on Com O. Pleas Check port settings and retry--Server Access Failed , Unabled to locate the update Version file .This is usually caused during server maintenance or when files are being updated Pleas try agian later ,BUT Teck said theres no maintenance He walked me through I think everything
ME really stood for Mostly Excrement.
Win 98 and ME have been declared 'End of Life' by Microsoft and there are existing vulnerabilities in them that MS will never fix because they are no longer supported.
Time to upgrade to linux or XP.
The Problem is ,that it was showing COMP0 there is no compo its 1-5 so I had to go too my freinds too do the update. BUT I still cant get what some has said that they have is MPG ,Tech told me I will get it on the update OO WELL
internet connection
It also sounds like you could have a slow internet connection. The download might be too big to transfer efficiently before the connection time out. Maybe the connection would be better another time? Although I have heard many bad things about ME too, sorry.
I had a similar problem trying to update my edge on my home computer with XP. It kept telling me the EDGE was disconnected, but it was connected. I stayed on the phone with tech support for 45 minutes. Eventually I went get my laptop and everything worked fine. I still cannot update with my desktop.
