supercharger program
Old Jul 24, 2006 | 07:30 PM
itimebomb89's Avatar
Unhappy supercharger program
Im thinking of slapping on an allen supercharger kit from troyer performance.
can i still use my hypertech tuning program(il lost it or 75 more hp)
but then i will not have my shift points, firmness settings and the governer will b back on and i dont want that. is there a troyer program that comes with the supercharger? i figure that there has to be a different programing for the computer but the supercharger instructions say that u can install it in your garage and run factory settings. it also sais to remove all chips or programs before install
Help
Old Jul 24, 2006 | 07:43 PM
jpdadeo's Avatar
Your best bet would be call Troyer Performance and talk to Mike about what you want; I’m sure he can deliver the goods
Troyer Performance, Inc.
Phone: (540) 862.9515
Old Jul 26, 2006 | 03:46 PM
Former Sponsor
You need to call us on this - we've tuned more of these trucks with that supercharger kit than anyone else, and have been a WD for AED blowers for years & years.
No, you CANNOT use your Hypertech off the shelf tuner, but you DO need proper tuning - I do NOT agree with AED or ANY other supercharger mfg company that tells you to install an FMU and run on the stock factory program - FMU's are dangerous and prone to failure thus leaning the motor and holing a piston, and force the PCM to be out of control of the fueling running at 100 PSI+ pressures under boost - that just is NOT the way to do things.
We can easily take care of all of that, so that you get much larger power gains than what just the blower itself does, and you will also have better fuel mileage, much better driveability, control over your shift points & firmness levels and so much more - just call us at our number listed below & we'll be happy to help.
I know it can be confusing with so many people telling you different things, but we have specialized in F-150 performance for 15 years, and know this extremely well, so we can set this up correctly and safely for you, so you can get exactly what you want - maximum safe & sustainable performance AND still have some control over your PCM.
