edge programmer
Old Jul 24, 2006 | 06:40 PM
bigbuckfx4's Avatar
edge programmer
Is anyone having any problems with there edge locking up or powering off. Im wondering is there something wrong with mine
Old Jul 25, 2006 | 08:46 AM
05supercrew's Avatar
No problems here. Give them a call.
Old Jul 25, 2006 | 09:12 AM
No problem here. Mine has been on about 10 days. I downloaded updates before the first install, it has worked perfectly.
Old Jul 25, 2006 | 11:37 AM
C-17 Pilot's Avatar
No problems here, either.
It sounds as if you have a loose OBDII cable. Check to ensure each end of the cable is securely attached to the Edge and to your truck's OBDII port. Also, check to ensure there are no bent pins, dirt, etc. in the cable or the port itself.
Good luck!
Old Jul 25, 2006 | 12:43 PM
bigbuckfx4's Avatar
Thanks for the info ill try that and see
Old Jul 25, 2006 | 04:09 PM
BlueOval Breath's Avatar
06 F150... No problems here. I did get the Newest updates before loading my truck. Everything is working great.
Question: Does anyone have any "Custom Loads" They like? Or point me in the direction of such previously titled threads... I have an 06 SuperCrew 4X4 5.4L. Thanks. BoB
Old Jul 25, 2006 | 04:30 PM
I would like to know what others are running as well: Mine is level 3
Shift points: 1-2 5200, 2-3 5200, 3-4 5000
Max RPM: 5400
Shift pressure: +18
Fuel: 1.8
Idle: 800 RPM
