Edge Setting Question
Old Jun 29, 2006 | 08:10 AM
jdoggfx4's Avatar
So I got my Edge and I love it. But I have a couple of questions.
I'm running the lvl 2 87 what should I set things at
1. WOT
2. Timming
3. Shift points.
4. Shift Pressure.
and what is the 12. 23. 32 setting inside each of these settings.
Any help would be great.
Old Jun 29, 2006 | 09:02 AM
Silverfish's Avatar
1 2 = first gear to second gear
2 3 = second gear to third gear
3 4 = third gear to fourth gear
check my signature for my settings on the edge.
Old Jun 29, 2006 | 09:15 AM
jdoggfx4's Avatar
Would the same settings work on the lvl2 87 octane?
Old Jun 29, 2006 | 10:17 AM
ThumperMX113's Avatar
Honestly, I'd back down your 4th gear shift a little. I wouldn't go above 4800 rpms personally.
Yes, except the timing.
Old Jun 29, 2006 | 10:34 AM
jdoggfx4's Avatar
so what should I set the timming to?
Old Jun 29, 2006 | 10:43 AM
jdoggfx4's Avatar
Also I noticed that my speedo is off by about 3 between what teh edge says and what teh speedo says. I did set it for 2660mm for the 325-60-18's but on the otehr page of my manual it says 33's are equal to 2632 any suggestions.
Old Jun 29, 2006 | 12:56 PM
chester8420's Avatar
Originally Posted by Silverfish
Best 0-60: 6.79 seconds (40 degree temp.)
DAMN!
Old Jun 29, 2006 | 01:22 PM
Kool Aid's Avatar
The speedo is always incorrect.
If the Edge is set correctly to the actual tire size (not from a chart) the Edge MPH will be correct. The speedo will never be.
Old Jun 29, 2006 | 01:49 PM
Jeeps&Fords's Avatar
Banned for Use of Multiple Usernames
All tires are slightly different. The only way to be sure is to measure your tires.
Old Jun 29, 2006 | 04:39 PM
turboscrew2005's Avatar
Here's my setting on level 2 w/ 89 octane.
WOT: 1-2 (5200) 2-3 (5200) 3-4 (4500)
Shift Firm: 1-2 (+2) 2-3 (+2) 3-4 (0)
Timing: (+2.00)
WOT Fuel: (1.20)
Haven't run any 0-60's or 1/4 mile runs yet.
