Jet Chip Installation Help 03!!!
Old Jun 21, 2006 | 10:06 PM
sraimist1's Avatar
I guess the title says it all. I need help installing my jet chip on my 2003 f150. It says that the ecu is located behind the kick panel on the passenger side. Where is the computer located and what do I have to do to gain access to it, and to install my jet chip? Any advice will help, and if theres a tutorial with pictures somewhere a link would be appreciated. Thanks. Oh, btw, its a 4.2 litre v6 2003 f150 to clarify.
Old Jun 22, 2006 | 07:38 AM
MGDfan's Avatar
Hi.
The chips usually come with docs.
I checked Jet's web site & no dice - only chebbie's.
Use the Search function here (I tried "install+jet+chip") ...
https://www.f150online.com/forums/sh...stall+jet+chip
And many, many more, including a lot that say NOT to buy a Jet Chip . Read up,
You can also try other F150 support sites - there are tutorials posted on them
I checked http://fordtruckworld.tenmagazines.com/howto.ten for you, and there is indeed a How-To for a Superchip install (same procedure), fourth link from the bottom. You will need to register to view it, though.
Good luck
Cheers
Grog
