new to site 06 f-150 performance questions
I just got a new 06 f 150 4x4 crew king ranch 5.4 l
ive done head unit, amp speakers running boards, wheels 20"
now on the performance end its a dog
my suburban blows it away
I just got an air raid and now its loud and i can hear it in the cab what can i do for 2 grand or so to make that thing faster I tried the hyper tech but the dealer couldnt get it to work
I was gonna try the magna flow and the hypertech again
is there anything better thanks
Hi jpaints,
Congratulations on your new F-150!
And don't worry, it's performance can *significantly* be upgraded with your budget - we offer all kinds of performance packages, and can do custom version of our performance packages for those who already have certain parts, like in your case, for example, since you already have the Airaid intake kit.
So don't despair, your F-150 can easily be made to have far better throttle response & performance, starting with our custom tuning added to a few other parts from one of our performance packages to meet your budget needs, no problem - and you'll be very happy with the results.
We know how you feel - yours is the single most often heard complaint about the new 2004 & up F-150's - the lack of throttle response & performance - but that is easily cured, and you can soon be enjoying far better performance as well as much better overall driveability than what you are experiencing right now - just give us a call at our number listed below & we'll be happy to help you with this.
Thanks for your post & enjoy your new truck!
got exhaust and tuner today help
I found a local magnaflow dealer and they put in a cat back
sounds good,
now I also got a tuner today hypertech and it wont work it says to call in and they were closes then it said it had several codes
p0600
p1000
p2100
p2104
p2105
p2107
p2110
u0300
then on the dash it said engine failsafe mode
sounds good,
p0600
p1000
p2100
p2104
p2105
p2107
p2110
u0300
Guest
Posts: n/a
sounds good,
p0600
p1000
p2100
p2104
p2105
p2107
p2110
u0300
sounds good,
p0600
p1000
p2100
p2104
p2105
p2107
p2110
u0300
The Hypertech's seem to have problems for '06 F150's. That was the first tuner I tried and I ended up going through 3 of them all constatnly throwing codes and repeatedly putting the truck into the failsafe mode. The dealer took it back because of all the problems and Hypertech does have a model version for '06 trucks but even that didn't work for me. Next up was a Flashpaq 1815, it just didn't do it for me and half of the features listed for the FlashPaq aren't yet available or activated. I ended up getting an Edge Evolution and am very happy with it. Many here say the Troyer Performance tuned Xcalibrator-2 is the bee's knee's. I have no hands on experience wth this tuner but Mr. Troyer has already replied in this thread he is very knowledgeable and friendly. Those would be the only 2 tuners I would recomend, the Edge and X-Cal2 for the '06's. Sad because I had a Hypertech on my '98 and was very happy with it.
As for performance, I have added a Magnaflow 16612 SI/SO exhaust, an Airraid CAI, the above mentioned Edge Evolution and Flex-A-Lite electric fans and replaced my serpentine belt with a Gatorback back to get rid of the annoying belt squeak. The performance gains are very noticable as is the improvement in overall drivability. I feel pretty comfy in stating I could smoke a Suburban, lol.
You have a great truck in the KR, welcome to the forum and best of luck. Cheers.
bummer
whenit was just starting to program it just stopped and said to call
i cleared all the codes and then tried it again and it just says to call so i dont know whats up with it, it didnt give me the option to go to stock it must not have programmed yet,
it did start up so it seemed ok i guess i shouls just take it back in the am
i guess i need to get hte other one that works i got the magna flow done today its fine
what is failsafe mode is it ok to drive in?
Guest
Posts: n/a
Originally Posted by SnowmaNick
First off, check the version code sticker on the back, that was what was first happening to me, as it was for '04-'05. I have no idea what changed besides VIN numbers but it ws a problem. Second, is the check engine light on currently and is it in Engine Failsafe Mode still? That is a limp home mode stating something is enough off the mark that it could damage the truck if run for a distance and/or speed. I personally wouldn't try to either run it far or take it to the dealer as they would ask if you did anything to the PCM and if code is in there your warranty is toast. Too risky for my blood. Hypertech is in Tennessee and they will probably ask a couple quick questions like is there anything including an alarm on your truck that wasn't theere from the factory. My truck had a dealer installed alarm put on it (Ford doesn't make alarms, just auto door lock/unlock, so if you have an alarm it was put on by the dealership or you). They will then tell you to turn it off from the powersource, meaning to pull the fuse for the alarm (have fun finding it as I had no idea and had to trace it from the brain to see where they tapped ito for a hot wire). Then they will tell you to try it again. That is the first layer you will go through. You could try this all tonight. It's a slow programmer and they also state to not have anything on (light, radio, a/c) and just to placate them I went there way and read a book with a flashlight. Beyond that they had me try a few things, none of which worked for me. When I was trying this it stalled out after I had selected my options and was in the reprograming stage. At this point the PCM had already been somewhat reprogrammed. If you go from the begining it should ask you to read/clear the DTC's, do that, then where you can select options/tuning level (if I remember correctly) you can select to return the truck to stock, select that and see if your Check Engine Light stays off and it is no longer in the Engine Failsafe mode (do a trip around the block a couple/few times giving the gas a goose now and then). Also, you could make sure to look at the Mass Airflow sensor cables are tight on your Airaid and that the shop put the O2 sensors back in properly after they installed the exhaust. If they are loose/unplugged it could be that your engine is reading lean from that.
i ve got so many adds on this thing alarm navigation brake controller amps back up cams----it just goes to program nad wont do anything else
I hope you mean you fired it up not fried it up lol. I'd still recommend a tuner, best mod bar none for me, but like I said, go with the Edge evo or the Xcal2. Once its in and running right you wo't ever want to drive without it.
ok now
its ok now got the edge when i returned the other one
when i talked to hyper thye said the error was some one had already used the programmer
put the edge in much better a little quicker
