X-cal2 from my 6.0 diesel---to E85?
Old May 30, 2006 | 04:22 PM
ISNMU's Avatar
I saved my xcal2 from my ford knowing I could use it on my 5.4... But since I ordered the E85 option, I was unsure if i can get a program for it? If it can be programmed, will it still adjust everything for use of ethinol or gasoline?
Old May 31, 2006 | 12:57 PM
ISNMU's Avatar
No one has a tuned E-85?
Old Jun 3, 2006 | 04:42 AM
Wilson502's Avatar
e85 has a different stoich ratio than normal e10 (10% ethanol blend). I would assume it would require different mapping for the air fuel ratio. Since e85 is higher octane (about 104 octane) you can run more spark timing. Troyer has answered this ? before.
Old Jun 6, 2006 | 04:38 PM
Former Sponsor
Hi ISNMU,
Yes, we can tune those E-85 vehicles, no problem. The stoich point changes significantly at that percentage of alcohol, but hat is easy to compensate for in our tuning.
Just give us a call at our number listed below & we can go over this with you - and congrats on your new truck!
Old Jun 7, 2006 | 08:24 AM
ISNMU's Avatar
Thanks I will call. I would like to be able to keep the E85 possibility open and also be able to run normal fuel.
Old Jun 12, 2006 | 01:00 PM
Former Sponsor
No problem, happy to help!
