Ethanol in gas ( Tune change? )
Old May 17, 2006 | 08:07 AM
RI995.4L's Avatar
With the new introduction of Ethanol in the local gas here ( was MTBE)..... I have noticed a pretty obvious change in performance.
I have a 5.4L with a Troyer Xcal-2 that Mike did for me early last year. The gas just recently changed here ( in Rhode Island) within the last couple months.
Is this common? Should I send it back for a "Re-tune" ??
Nothing has changed on my truck. I just keep up with normal maintenance as usual.
Thanks,
jon
Old May 17, 2006 | 06:43 PM
RI995.4L's Avatar
Anyone????
Hello?
Old May 17, 2006 | 06:51 PM
TSDan's Avatar
How much ethanol?From what I understand the E85 Ethanol mix is 100 octane
Where I live it is a standard 10% mix by law and the octane on the pump is what we go by!The difference now is the last of the winter blends are being used.You need not change anything.Do not use e85 mix unless your truck is made for its' use.A vehicle manufactured to use unleaded fuel cannot use E85 unless you get the fuel tank changed,the fuel lines changed and I think the fuel pump.E85 is more corrosive and will do serious damage to a vehicle that is not made for its' use
Old May 17, 2006 | 09:21 PM
JerryM's Avatar
Lots of information on E85 here: http://xcelplus.com/e85/article.htm
-Jerry
Old May 18, 2006 | 12:01 AM
cwbpro69's Avatar
I believe he is talking about the mix of ethanol 10- 15% in with the gasoline instead of the NTB (I think that is the name) that they have been using for years. They are doing this with some of the gas here that we get in Texas. I noticed that the average MPG on this last tank that I calculated got 10-11 mpg half city/half highway driving. I will make sure and not fill up with an ethanol mix gasoline until I absolutely have to.
I would just try to find a gas station that is not blending ethanol with the gasoline instead of NTB ( I think thats the name) for right not.
Old May 18, 2006 | 12:26 AM
Squeakers's Avatar
For those of us up here in the north country, ethanol in gas is common. If I asked how many of you that live down south have ever heard of heat in the yellow bottle. It is basically ethanol to put in the tank during the winter months to absorb water, it can also start a vehicle. We have our 87, 89 with 10% ethanol, and 91 or above. Also with the introduction of E85 which is 15% gas and 85% ethanol. I have an edge tuner and commonly run 89 with 10% ethanol and have had no problems with it what so ever. I would not reccomend running E85.
Old May 18, 2006 | 06:07 AM
Tucker1154's Avatar
We have seen A/F's go as much as 3/4 point leaner with the new gas here in VA (10% E)
Jay
Old May 18, 2006 | 06:50 AM
RI995.4L's Avatar
Jay
Exactly, Ethanol adds oxygen.
The MTBE that has been being added did contain an ethanol component but not in such volume it is now.
With more Ethanol comes more oxygen = more of a potential for a slight lean condition.
Hence my question about the tune.
Maybe Mike will peak in here.......
Thanks guys
Old May 19, 2006 | 01:19 PM
tschaid's Avatar
Jay
Hold on a second. 10% Ehtanol will easily be handled by the O2 Sensors and the trucks PCM (if the O2 Sensors) are actually working - they may have issues and just haven't lit up a CEL yet. I sure hope this statement is based upon a before and after comparison. Remember, a number of these trucks are lean from the factory. I am in the process of converting my truck into a FFV. Currently, I am running a 78% Gasoline / 22% Ethanol mixture. I have a Wideband LM-1 attached to my truck and am monitoring for adjustment. After the first 30 miles, no adjustment has occurred yet. Do I expect an adjustment ? You bet; but, the adaptive strategy will take awhile. We do know that the adjustment range built into our trucks is quite narrow.
As for running E85. Within a month or so, I will be running E85 straight from the pump and then intend to mfgr my own. Sound crazy?? Perhaps; but, as long as I get enough fuel into the chamber, the truck will be alright.
Old May 19, 2006 | 08:10 PM
TSDan's Avatar
tschaid said*As for running E85. Within a month or so, I will be running E85 straight from the pump and then intend to mfgr my own. Sound crazy?? Perhaps; but, as long as I get enough fuel into the chamber, the truck will be alright.[/QUOTE]
Damn-it boy send me a gallon cause I'm thirsty and I love corngrain!!!!!!!
Old May 19, 2006 | 08:44 PM
chester8420's Avatar
-Jerry
That was some VERY informative reading. Thanks for posting it!
Old May 19, 2006 | 08:53 PM
more oxyegen advances timing too. Gets worse mpg, all in the name of a "better" burning fuel
also costs more to produce
-Patrick
Old May 19, 2006 | 10:38 PM
Danoshere's Avatar
RI995.4L, Found this in another thread from Mike Troyer:
Originally Posted by Superchips_Distributor
I'm Sooo glad this topic came up, as it is indeed a hot one.
...the answer many of you are looking for is NO, your do NOT need tuning changes - your PCM will be able to keep up with this change no problem, the 10% ethanol-blended fuels have about a 14.2:1 stoich point and the O2 sensors will automatically start switching there instead.
The main thing is that you simply lose a little bit of peak power and fuel mileage due to the lower BTU content of the portion of the fuel that is ethanol.
And by the way - for many years now, it has been a *requirement* that the fuel systems of all vehicles here in the US be able to run on a 10% ethanol mixture - yes, alcohol-based fuels are indeed more corrosive, and they have about half the BTU content of "normal" gasoline - but they also have a high octane number, and if tuned for to the nth degree, we could get a 20% power gain from it - why do you think Indy cars run on methanol?
So all of you can rest regarding is it OK to run your custom tuning on 10% ethanol blends, you've been doing it for years & years already, every winter - you just don't make quite as much power or get quite as good fuel economy, basically.
I hope that helps,
So there is your answer
Dano
Old May 20, 2006 | 08:49 AM
RI995.4L's Avatar
Hey thanks a bunch Dan
I must be suffering from another underlying problem then. Damned if I know what it might be ......unless something dies or throws a code I am stumped.
Thanks again folks
Jon
Old May 20, 2006 | 11:22 AM
tschaid's Avatar
Damn-it boy send me a gallon cause I'm thirsty and I love corngrain!!!!!!![/QUOTE]
I haven't been called "boy" in a long time. Dunno who you are; but, "boy" is not appropriate. I knew my comments would create somewhat of a stir. Hmm. That's ok. Unfortunately, the ATF allows the manufacture of acholol in your backyard only if the result is not drinkable so while I would love to provide some for you, I can't.
Also, to Mike Troyer's point. 50% BTU content when compared to Gasoline. Mike, you and I have had a number of conversations and each time I have talked with you, I have walked away with more knowledge than I had before; but, this I have to challenge. 50% ??? I sure would like to know what data you have that the Ethanol community does not. Everything I have read suggests the BTU content is in the 80% range not 1/2 as you stated.
