Programmer help....newb
It's been a while since I've posted, sorry.
I have an 01 screw with only a cat-back on it. Been wanting to do a programmer, just didn't know what to use. Can anyone help with some suggestions?
I am ordering a K&N cold air kit next week, but that is about all I'm gonna do. Maybe change the rear-gears to 3.73, since I put 20's on it. But that is about it. I use this truck to haul my race car, so I don't want to get carried away with the mods.... which I usually do. LOL
Tuner- XCal2
CAI- Air Force One
The AF1 will produce much better numbers than the K&N hands down.
Give'm a call at www.troyerperformance.com and they will answer all of your questions and get you all fixed up. Do a search on this forum on the XCal2 and you can see how pleased everyone is who has one.
Greenhaw
CAI- Air Force One
Greenhaw
Hi Niceguy,
Welcome back!
For programming, what will get you the best results is to go with our Troyer Performance custom tuning - we've specialized in tuning the F-150 longer than anyone else, and are very well known for our results.
We deliver a set of 3 different custom tunes, set up however is appropriate for each individual vehicle owner's needs, and provide them in the most advanced hand-held tuner on the market, the XCalibrator 2 - it has complete enhanced-parameter diagnostics as well as a high-speed datalogger built in, and many other features, such as Internet-updateable firmware, USB connectivity to your PC, and much more.
Just as an aside, with regards to your potential gear ratio change, I strongly advise going to 4.10's instead of just 3.73's for those 20" wheels - 3.73's really don't do much, and the 4.10's give you must more torque multiplication without a penalty in fuel mileage - in most cases, unless your cruising speeds are significantly in excess of about 80 mph, you generally won't see the mpg drop, and in many cases, it actually goes up a tiny bit due to reduced load on the motor.
One other point - the K&N intake kit works well, but if you really want to get the most out of the air intake tract, the Air Force One gains about 3 HP more than the K&N FIPK - if that matters to you - just FYI.
If you;d like to go over any of this in more detail, please feel free to give us a cal at our number listed below & we'll be happy to help.
Thanks for your post, & best of luck whatever you decide!
Welcome back!
