Quick Tuner/Edge question
Old Jan 14, 2006 | 08:28 PM
campinfamily's Avatar
While in tow mode, or any mode for that matter, can you still use 4wd as you would normally? This may be a dumb question......but I do not recall ever reading anything about this.
Old Jan 14, 2006 | 08:32 PM
nvrenuff's Avatar
yes you still use it normally, not an issue.
Old Jan 14, 2006 | 08:33 PM
Thanks, I was afraid to break or mess somrhting up
Old Jan 14, 2006 | 08:47 PM
nvrenuff's Avatar
I have read however that the combined use of the edge and excessive 4*4'in with your truck like jumping it, running over medium sized trees and swamping it will adversely affect its longevity.
Old Jan 16, 2006 | 10:22 AM
Former Sponsor
Hi campinfamily,
As the others have responded, you are not limited in any way with regard to being able to use your 4WD capabilities when using our tuning or that of most others. About the only thing you want to pay special attention to are any notes in your owners manual regarding at what speeds you can engage 4WD, and depending on model year, if you need to back the vehicle up a little bit to disengage it fully, etc.
In other words, there basically are no additional concerns other than what is already stated in your vehicle's owners manual.
Good luck!
Old Jan 17, 2006 | 07:24 PM
Originally Posted by Superchips_Distributor
Hi campinfamily,
Good luck!
Thanks MT I appreciate your feedback.....makes me feel more confortable..
