04 5.4 3 valve programmer
Old Aug 6, 2005 | 11:40 PM
GBAUTO's Avatar
need some feedback on which programmer to use for my 04 f-150 5.4. what i'm looking for is to get better throttle response(not the delayed b.s. that it has now) and perhaps upping the rev limiter and shift points. i want to be able to continue to run regular through it so max performance is not a priority. thanks in advance.
Old Aug 7, 2005 | 01:32 AM
JerseyGeorge's Avatar
Xcal 2 programed by Mike Troyer. Programmer with three custom tunes in any octane you desire. Check the "supporting Vendors" section for Performance Products aka Mike Troyer aka Superchips Distibutor here on the forum.
Old Aug 7, 2005 | 01:33 PM
GBAUTO's Avatar
thanks, does that program allow for extended towing? i pull my race car( about 5000 lbs) to the track and it does it with ease now. i just don't want to have to use premium($). i'm mostly looking for better throttle response. any body out there have some real world comments on using a regular gas tune? difference in throttle response and possible changes in fuel economy. inquiring minds want to know...
Old Aug 7, 2005 | 05:07 PM
jpdadeo's Avatar
As JerseyGeorge says, Xcal 2 programmed by Mike Troyer. It will address every issue you posted and much much more.
XCal2
Old Aug 8, 2005 | 05:18 PM
Former Sponsor
Hi GBAUTO,
Yes, we can set you up with everything from 87 octane tunes to all-out performance tunes to towing tunes, etc - everything you need.
We deliver you with a set of 3 different custom tunes set up for your specific needs, and those 2004 & newer 5.4 3V trucks definitely need a lot of improvement in the throttle response & power department - we can easily take care of that for you.
Just give us a call at our number listed below & our staff will be more than happy to go over all of that with you.
Old Aug 8, 2005 | 05:38 PM
shookman34's Avatar
GBAUTO....get the XCAL2 from Troyer Performance. It is worth every penny...just read through all of these posts under Chips/Programming.
