TP, can you check this custom tune list?
Mike at TP, can you check this custom tune list?
Ordering the Xcalibrator 2 from you as well as some upgrades, does this sound like a good mod path as well as what you would suggest to use the 3 custom tunes for?
92-94 oct. fuel around here.
Custom Tune #1:
Computer Code: SVB2
Stock 5.4 4x4 Supercab XLT Off Road
Stock 3.55's L.S.
BF Goodrich All-Terrain TA KO 265/70-17 Tires
K&N FIPK Kit (57-2514-4)
Magnaflow (15749) SIDO Split Rear exhaust
Denso IT-16 plugs with 8 steel Big-Sert inserts thanks to Ford
Goodyear Gatorback belt
Rancho RS9000X
Cervini's Ram Air Hood (Non-Functional
Transgo shift kit (AODE4R7OW-HD2)
Dual 16" Electric Fans Kit (PPI-EFK)
Underdrive Pulley Set (528774)
200 Amp Alternator
Troyer Performance Active Automatic Transmission Cooler Kit (PPI-ATCKIT)
Custom Tune #2: * = Adding to Tune #1
Computer Code: SVB2
Stock 3.55's L.S.
Rancho RS9000X
200 Amp Alternator
* Headers (shorties or long?)
* Magnaflow highflow cats, X pipe, mufflers (Entire exhaust replacement)
Custom Tune #3: * = Adding to Tune #2
Computer Code: SVB2
Stock 3.55's L.S.
Rancho RS9000X
200 Amp Alternator
* 90mm MAF
* Edelbrock/BBK 75 mm Throttle Body
* 24# Fuel injectors
* New Fuel pump
Thanks,
Keith
Custom Tune #1:
Computer Code: SVB2
Stock 3.55's L.S.
Rancho RS9000X
)Transgo shift kit (AODE4R7OW-HD2)
200 Amp Alternator
Computer Code: SVB2
Stock 3.55's L.S.
Rancho RS9000X
200 Amp Alternator
Computer Code: SVB2
Stock 3.55's L.S.
Rancho RS9000X
200 Amp Alternator
* 90mm MAF
* New Fuel pump
Thanks,
Keith
. Placed my order today.
