what gear ratio do i have?
Look at the label in the drivers door jam area.
Your axle indicator will be found on the Certification Label
bottom line in the middle labeled AXLE.
Wright in the code you see right under this. He should be able to tell from this what ratio the truck has.
On the driver side door pillar down near the bottom on the white tag you’ll find the axle ratio code
Axle Codes
non-limited slip
X27 – 3:31
X19 – 3:55
X26 – 3:73
X25 – 4:10
limited slip
H9 – 3:55
B6 – 3:73
B5 – 4:10
Axle Codes
non-limited slip
X27 – 3:31
X19 – 3:55
X26 – 3:73
X25 – 4:10
limited slip
H9 – 3:55
B6 – 3:73
B5 – 4:10
