chip for 1990 F150
Old Nov 21, 2004 | 11:38 PM
HecTiK's Avatar
chip for 1990 F150
What chip would I use for a 1990 F150 with a 300 I-6?
Old Nov 23, 2004 | 08:40 AM
IzzyEddy's Avatar
Cool
HecTik,
you need to get the chip code off of the door panel or the computer itself. You may find the computer code in the door jam (I believe it is the passenger's door) OR the computer is behind the emergency brake assembly in the driver's side kick panel. If you can't see the code through the assembly, three nuts and you can move the assembly off the wall. The code should be similar to mine HUG0 and that is a zero on the end not a 'o'. Three letters and one number. Once you find that, you can call Mike and he can answer any question that you have about any modifications that you wish to do to the truck.
Have Fun & Keep on Truckin'
Dean
Old Nov 23, 2004 | 05:27 PM
Former Sponsor
Hi HecTik,
What Dean (IzzyEddy) said is exactly right - locate the computer code where he mentioned and then we can see if we can provide the tuning for you.
If you have any problem finding this computer code Dean's talking about, just give us a call and we can help you with that - sometimes those older trucks don't have the full 4 digits (3 letters and 1 number) - sometimes in the older trucks it's a 3-digit code, for example.
Anyway, if you don't seem to be able to locate it, just give us a call at our number listed below & we can go over all of this with you in proper detail, help you locate your truck's particular computer code, etc.
Good luck & talk to you soon!
