Cant wait...must have...chip..now!
Oh someone save me..it wont be here till Tuesday! That means....um..100 or more hours! Someone entertain me with some kills or something
Former fast46triton
2001 Ford F150 XLT Supercab, Silver two-tone with deep wedgewood blue on bottom, 5.4l Triton V8, SUPERCHIPPED! 3:55 LS Gears
Upcoming mods!
1) FIPK
Former fast46triton
Upcoming mods!
1) FIPK
The anticipation is a killer, eh.
I was out of work (with an injury) when I ordered mine. I was practicly counting the minuets. Then the Superchip comes in (like Mike said, two buissness days) and I wasn't able to put it in for a few more days.(damn surgery!)
It's been in since mid March. Now it's time for an oil change. I get to take the thing out and start over. I dread driving this truck with out the Superchip. When I put it back in, I will have an even bigger appreciation for it.
I hope time flys for you. Good luck on the install. Keep the directions handy.
Tom
Tom
fast,
It's been a couple of years that you have been talking about a chip. What's a few more days? May I suggest that you take out your computer, while you're waiting, and clean the coating off of the contacts. That way, when your chip arrives, all you have to do is pop it in.
2000 Regular Cab Short Box XLT 2WD 5.4 silver 3.55 LS 4 wheel antilock discs
PERFORMANCE MODS
Superchip Flip Chip, K&N Air Filter, Gibson Stainless Split Rear Cat Back with Ravin Muffler, Edelbrock IAS Shocks, Hellwig Front Sway Bar
APPEARANCE MODS
17x8 TSW Trackers, 285/60-17 Pirelli Scorpion Zeroes, ARE LSII Fiberglass Tonneau, 2 inch drop shackles, Ford factory fog light kit, Custom Made 5.4 Fender Badges, Grill off of my brother's Lightning
STEREO MODS
Pioneer DEH-P7200 CD Receiver, MTX Road Thunder RT4340 4 Channel Amplifier, Infinity Kappa 572.1cf 5x7's in the doors,MTX Thunderform with two 10" MTX Thunder 6000 Subs
PROTECTION
Valentine 1 Radar Locator with Remote Display
PERFORMANCE MODS
APPEARANCE MODS
STEREO MODS
PROTECTION
just a socket wrench--i took the battery case out also had to because of 4x4, but would have any way real easy to work on then.
read this first:
http://www.f150world.com/superchip.asp
2001 F-150 4X4 Supercab
XLT 139" WB style side
5.4L V8 3.55 LIMITED SLIP AXLE
MODS:
AIRAID FIPK
SUPERCHIP(FLIP CHIP)
ROLL & LOCK TONNEAU
sitting in garage mods
GIBSON CAT BACK
GIBSON HEADER
REFLEXX COBRA HOOD
STREET SCENE GRILL
HOLLEY THUNDER SUPERCHARGE
ALL TO BE INSTALLED IN 20 DAYS
read this first:
MODS:
AIRAID FIPK
ROLL & LOCK TONNEAU
GIBSON CAT BACK
GIBSON HEADER
REFLEXX COBRA HOOD
STREET SCENE GRILL
I love that article, I read it like 20 times
Do I have to disconnect the negative terminal on the battery just to clean the contacts?
Former fast46triton
Upcoming mods!
1) FIPK
Former fast46triton
Upcoming mods!
1) FIPK
Hey Fast,
If you want to know how we feel about this, we'd really prefer that you had our documentation before removing the computer & cleaning the contacts, etc., as we have gone to great lengths to write & give you highly detailed instructions on doing all of that, from start to finish, including very important visual characteristics to look for when cleaning those contacts.
If you like, that can even be emailed to you, just shoot me a quick email and we'll reply by attaching that info to our response if you like.
It's up to you of course, but all your questions and far more will be answered just by reading the documentation that we provide with the Superchip, along with other numerous tips & details, troubleshooting info, etc.
All that having been said, if you want to have at it, that's up to you!
You do not have to remove your battery unless there are components on the firewall above the wiring harness that block your access to ths computers' wiring harness, like in the case of any F-150 with the Offroad package, for example. Even then, if you have an extension & swivel socket, you can still avoid battery removal in many cases. If you have large hands, count on removing the battery anyway, and it's easy, pulling the battery is a 5 minute job.
To remove the computer, you must loosen that 10mm bolt head (which remains an integral part of that harness, so you won't be removing that bolt, just loosening it a good deal) that is in the middle of the wiring harness, and as you do that, the harness will slowly back off of the front of the computer, until you can detach it. Then go into the cabin, and remove the black pressure clip that holds the computer against it's mounting bracket.
The computer is located to the right of the dash assembly, and above the passenger's kick panel. Once you remove that black pressure clip, that's it, you can then pull thw computer itself out.
Make sure to remove the top & bottom covers of the computer, so that you will have enough room to properly clean that connector, don't try taking a shorcut by not removing the covers. When cleaning those contacts, make sure you don't go too far, you don't want to go all the way down into the copper when scraping. Scrape thoroughly, but lightly, in other words. The conformal coating that has to be removed is clear in color, so it can be tricky for a first-timer to tell if it's all removed or not, just take your time. When scraping that coating off, it will turn white where it's penetrated or "cut", making it easier to see it. Just take your time, and don't rush this.
Again, we'd prefer that you had all the instructions & documentation that we provide with the Superchip before you do this, but if you're determined to do this ahead of time, please just be careful, and don't do anything you're not comfortable with or that you're not sure of. Call me even over the weekend if you need to, and leave a voicemail, & we'll get back to you, Fast.
Another poster mentioned that you've been waiting for years to do the Superchip, and that what's a couple more days. I agree completely!
We're just happy for you, that you're going to be able to do it, after all this time. We hope the wait will have been worth it for you!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
You do not have to remove your battery unless there are components on the firewall above the wiring harness that block your access to ths computers' wiring harness, like in the case of any F-150 with the Offroad package, for example. Even then, if you have an extension & swivel socket, you can still avoid battery removal in many cases. If you have large hands, count on removing the battery anyway, and it's easy, pulling the battery is a 5 minute job.To remove the computer, you must loosen that 10mm bolt head (which remains an integral part of that harness, so you won't be removing that bolt, just loosening it a good deal) that is in the middle of the wiring harness, and as you do that, the harness will slowly back off of the front of the computer, until you can detach it. Then go into the cabin, and remove the black pressure clip that holds the computer against it's mounting bracket.
We're just happy for you, that you're going to be able to do it, after all this time. We hope the wait will have been worth it for you!------------------
Mike Troyer
(540) 862-9515
Yep, guess I do.
So Ill have to remove the battery to get to the front of the computer? Ack!
On the 2001, will the computer be on driver or passenger side?
[This message has been edited by fast54triton (edited 05-12-2001).]
Thanks Mike! Well, its Sunday, and just two more days! Keep countin em down!
Former fast46triton
Upcoming mods!
1) FIPK
Former fast46triton
Upcoming mods!
1) FIPK
Did you hear about the UPS wildcat strike? Fed-Ex will honor the pickets also....
Sorry...this thread was way too slow......
1999 F250 SD CC, LWB, 5.4L, Auto, 3.73, 4x4, Power TT mirrors w/ marker lights, White, Full Tint, PendaPro SR, Dynomax Race Magnum Bullet, K&N filtercharger, Superchip(MER3 for sale!!), Superlift leveling kit, Rancho RSX shocks, Pace Edwards Roll Top Cover
www.angelfire.com/pa3/spaceace/index.html
GAH!
Mike quick, wheres my superchip at now?
<gets keys ready>
MIKE!
Former fast46triton
Upcoming mods!
1) FIPK
<gets keys ready>
MIKE!
Former fast46triton
Upcoming mods!
1) FIPK
fast54triton:
Nice Captain Kirk'ish topic title.
Hope the Remulons (sp?) aren't chasing you, cause I'm sure you're "givin' it all she's got running on impulse power".
Wilk
'97 F-150 4x4 Super Cab; XLT 139" Wheelbase Flairside; Silver Frost Clearcoat; 4.6L. (Romeo); 4-spd Automatic Transmission; Preferred Equipment Package 507A; 3.55 Limited Slip Axle; Electronic Shift 4x4; California Emissions; Sliding Rear Window; Trailer Towing Package; Off-Road Package; 6-Way Power Driver's Seat; Remote Keyless Entry/Anti Theft; 6-Disc CD Changer; Ford Bedliner; Ford Running Boards; Ford 600 Plus Vehicle Security System; Ford Nose Mask; Roll n Lock Tonneau Cover; Ford PremiumCare Extended Service Plan (5 year/100,000 miles).
2000 SVT F-150 LIGHTNING XLT; 120" Wheelbase; Flareside; 5.4L EFI SOHC V8 SC Engine; 4-SPD Automatic; Silver Clearcoat Metallic; SVT Online Store Lightning Front End Mask; Roll n Lock Tonneau Cover.
Wilk
Runnin the regular gas down as much as I can
Former fast46triton
Upcoming mods!
1) FIPK
Former fast46triton
Upcoming mods!
1) FIPK
Fast - Know how you feel. That's why I had both of my Superchips sent "overnight". Cost a little more, but less painful.
2000 F150 XLT SuperCab, Short Bed, 4X4, ORP, 5.4L, Auto Trans, 3.55LS, Captains Chairs with power drivers seat, rear slider, class III towing package, remote entry with alarm and just about everything you can get on this truck. Added a Ford bug deflecter, floor mats, a Dynamax Race magnum muffler and 3" mandrel bent pipes, Superchip, K&N FIPK Gen II, Bilstein shocks, Redline Synthetic oil, Kenwood stereo system, an MTX Thunder 204 4 channel amp, ProComp AT 33/12.50/17 tires and 17X8 American Racing Python wheels.
LOL Mike!
Tomorrow...I hope! Ill get home ASAP from school and if I see the brown UPS bag...Im gonna go nuts and tear it open
Any install tips Mike? Some people complained about the clip, that holds the computer, like its hard to pull the computer from it. Will this cause me any problems?
