10 MPG ouch!
Old Apr 18, 2001 | 03:19 PM
bikestudga's Avatar
Post 10 MPG ouch!
Hey all - I have a '01 Harley SCrew, chipped. I'm using Texaco fuel since the first tank. I'm getting 10 mpg!
Any clue as to whether there's a problem or not? I have laid off the pedal as much as I can ...
jeff
'01 HD SCrew
Old Apr 18, 2001 | 03:37 PM
moose-man's Avatar
Post
hey bikestudga,
Provide more information
like what engine do you have any mods? tires size gear ratio etc.. then im sure somebody can help!
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
[This message has been edited by moose-man (edited 04-20-2001).]
Old Apr 18, 2001 | 03:51 PM
bikestudga's Avatar
Post
err..
it's a harley - so it has standard stuff
5.4L V8, 20" wheels, 3.73 rear, superchip... that's about it... no fipk, no tb spacer.
still 10 mpg.... ouch! fuel's $1.69/gal... $40/tank's gonna get a little much after a while.
[This message has been edited by bikestudga (edited 04-18-2001).]
Old Apr 18, 2001 | 03:55 PM
smcconaghie's Avatar
Post
i'm not sure why it is so low..
i get about 15 mpg around town, and get 18 on the highway..
that may improve when I get my hard tonneau in a couple weeks.
'99 Ford F-150 Lariat SuperCab 4x4, ORP, 3.73 gears
5.4L Triton V-8
Deep Wedgewood Blue
MODS:
MODS TO COME:
Old Apr 18, 2001 | 04:12 PM
ragarm's Avatar
Angry
Super Unleaded just hit 1.99 here in town...OUCH!
* 2000 F-150 XLT Black FS; 5.4L; 4x4 ORP
* Da Flip Chip! * 3.55 Limited Slip * Stepups
* Sliding Rear Window * 6-Way Power Seat
* Remote Keyless Entry
* Lund Trident Bug Shield * Custom Exhaust
* Fumoto Oil Drain Plug Valve (a must for do-it-yourselfers!)
* Wise Bedrug
So many mods, so little cash! On the up side, no wife to create a filibuster.
Old Apr 18, 2001 | 04:14 PM
Snyper's Avatar
Post
My 2000 Harley truck started out at about 12.5 MPG. After adding a K&N FIPK and a Superchip, plus about 4500 miles I'm now getting between 17 and 18 MPG. If your truck doesnt improve I would think there is a problem. Yours is heavier than mine but 10 MPG is ridiculous!!
2000 Harley/Davidson F-150
Lund Bug Deflector
Ventshades
Century "Cargo Cover"
K&N FIPK Gen II
Superchip!!!
89 F-150 Lariat 4X4 for the "dirty work"!
Old Apr 18, 2001 | 04:38 PM
JMC's Avatar
JMC
25 Year Member
Post
Jeff,
How are you calculating your milage per gallon?
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Hedman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Apr 18, 2001 | 06:29 PM
bikestudga's Avatar
Post
calculation:
trip mileage divided by amt of new fuel added.
I got 11 on the highway during break-in... just wonder what's up...
Old Apr 19, 2001 | 03:12 PM
Former Sponsor
Post
Super Crew's are the among the very heaviest configurations of the F-150 available, so they're never going to get "good" mileage, either stock or modified.
Without seeing how you're operating your vehicle, it's impossible to tell if 10 mpg is a reasonable figure or not, there are too many other factors involved. Also, due to the rather extreme differences in weight based on configuration in these F-150's, you cannot compare your mileage results to any other F-150 except another 5.4 3.73-geared Super Crew. (I'm assuming that's your configuration)
It takes anywhere from a minimum of 4000 to as much as 8000 miles on a brand new vehicle before you will see the engine make it's peak power and get it's best mileage, just in case you may not be there yet.
The only way your gas mileage can ever go down using the Superchip is if you either drive it harder than you did before chipping it, or if the premium gas you're using now has a lower energy content than the regular gas that was previously being used before installing the chip.
Generally speaking, Texaco tends to have one of the consistently higher energy contents, so it's usually one of the best fuels available in any given geographic area. There are of course exceptions, so if you want to see which gas is going to give you the best results where you are, use 3-5 tanks of each different brand in your area, and use the one that gives the highest mileage results under the same driving conditions. (Note: You can skip evaluating Exxon, as it is consistently lower in energy content compared to almost any other "name brand" fuel in all 50 states, as it is "reformulated" year-round and has been for a few years now .)
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
