OBD II Code Scanner & Superchip
Old Mar 27, 2001 | 09:37 PM
BluOvalOK's Avatar
Post OBD II Code Scanner & Superchip
Question:
I just ordered an OBD II Diagnostic Scanner (Actron CP-9035), Do I need to remove the chip before I run the scan?
Havent got the scanner in the mail yet so I thought I would ask ahead of time.
Thanks,
Trey
'97 Expy 4.6L, 2wd XLT, Airaid Intake
Rancho 5000
Superchip
Ravin Z-77 Exhaust
Raybestos Ceramic Brake Pads
Old Mar 27, 2001 | 10:26 PM
redlariet's Avatar
Post
The chip can stay and the codes are still read. Just ignore the one about the internal eprom not working.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-Airraid-Perma-cool electric fan & controller
Old Mar 28, 2001 | 02:33 PM
Former Sponsor
Post
Hi BluOvalOK,
What "redlariet" said is correct.
With the Superchip attached, you are going to get what we refer to as a "false" error code, and specifically, it will be a P0605 error code. This indicates that the computer's internal eeprom chip is not functioning, and this is supposed to happen anytime you have a chip attached to any Ford computer's rear connector. In fact, that is exactly why we recommend removing the Superchip prior to going into your dealer for service, so the technician won't think there is actually something wrong with the computer. That P0605 code will go away as soon as you remove the Superchip, and will come back whenever the Superchip is installed, so it should be ignored when the Superchip is installed.
So you can just leave the Superchip in place and ignore that P0605 error code, as the Superchip being installed while scanning will not interfere with your ability to get any error codes.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old Mar 28, 2001 | 11:15 PM
BluOvalOK's Avatar
Post
Okay, I ran the scan but I didnt get the 605 error. Just the same Evaporation Emissions Control Vent System I have had 4 times now(the reason I bought the damn scanner in the first place).
Why didnt I get the 605 error? Is it normal?I hope it is just because of the latest firmware revision to the code scanner. I would hate to think the Superchip isnt properly installed. The service mgr. said he got an error when he scanned it. What the crap!
Airaid Intake
Rancho 5000
Superchip
Ravin Z-77 Exhaust
Stereo Mods:
Infiniti Kappa 5 X 7 doors
JL Audio 10" sub rear cargo area
Alpine Flex5 amp under pass. seat
Old Mar 29, 2001 | 01:14 PM
Former Sponsor
Post
Hi BluOvalOK,
Hmm, I don't know why you didn't get that code when you scanned for error codes, if you had the Superchip installed while you did the scan. Sounds like it might be something to do with your scanner, since your service department got the error too.
Anytime any performance chip is attached to the J3 edge connector on the back of the Ford computer, you're going to get that P0605 error code, as the computer's internal eeprom chip has been turned off by engaging that circuit. This isn't something that just happens sometimes, or in some cases, this will happen *always* when scanned by Ford's SBDS (service bay diagnostic system) with the Superchip installed.
This may be something that this particular scanner just doesn't check for, perhaps, I don't know. We're used to dealing with what happens when vehicles are scanned at the dealership, using Ford's SBDS system. So it may be different for other types of scaners, that I really can't tell you.
As long as your engine starts and runs normally with the Superchip attached, the Superchip is communicating with the computer as it should.
Good luck!
Mike Troyer
(540) 862-9515
Old Mar 29, 2001 | 07:51 PM
redlariet's Avatar
Post
BluOval
I'll plug in mine tomorrow & post back here.
Old Mar 29, 2001 | 09:27 PM
BluOvalOK's Avatar
Post
Thanks guys-
I checked to make sure the chip was still in place and it was (I secured it with a strip of velcro). So maybe its the "Actron CP9035" scanner.
Thanks for all the help. Now I need to find the Emission Control Vent and replace it.
Airaid Intake
Rancho 5000
Superchip
Ravin Z-77 Exhaust
Stereo Mods:
JL Audio 10" sub (rear cargo area)
Alpine Flex5 amp (under pass. seat)
Old Mar 31, 2001 | 09:48 AM
redlariet's Avatar
Post
BluOval
I plugged in the actron & got 0 with the chip in.
