Superchip Performance -- unscientific results
Last week before installing my Superchip, I brought my truck out to get a feel for 0-60 times. The (unscientific) procedure was using a stopwatch for three consecutive runs then taking the average. The result for the stock 5.4L engine on my Supercab 4x4 was about 9.05 seconds.
After installing the Superchip, I performed the same procedure and my average dropped to 8.5 seconds.
I know this may not be a completely accurate read and I would be much better off getting 1/4 mile times on a track, however, given that the procedure was consistent is does conclusively show that there are pretty good performance gains to be had.
The better news... I have heard that additional gains can still be seen once the computer goes through its full relearn cycle (500-800 miles). I can't wait
2000 F-150 XLT Supercab, 5.4L, 4x4, 3.55 gears
- Smittybuilt sure step bars
- K&N Air Filter
- Ford Bedliner
- Class III Tow Package
- Superchip
interesting!
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
Hi Cyclone,
You're right, using a hand-held stopwatch isn't the most precise way of doing this, but if you're careful & as consistent as possible in terms of when you nail the gas to when you click the stopwatch, and the same with regards to when the speedo needle hits exactly 60 to when you click it off, then you can get close enough to determine the basic fact that it accelerates quicker with the Superchip than without it.
We normally see improvements ranging from a low of about 3 tenths in the heaviest trucks to as much as 6-7 tenths in the rest, and a few people have gotten even a bit more off their 0-60 times, so it sounds like what you're getting is very good!
Have fun,
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Have fun,
Mike Troyer
(540) 862-9515
I had similar results...I am at 7.8/7.85 seconds with almost 4,000 miles on the relearn cycle. My stock 0-60 was in the mid 8's (4x2). Not bad at all for a 5,000 lb hunk of steel.
I do have a K&N filter which I'm sure helps a little.
Either way, well worth the investment to me!
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/auxiliary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil, build 7/2000
I also put a Flip Chip just this am.
I took my truck on the highway, WOW it just moves. Before realizing it was smoothly up to 90MPH, as a state trooper went by the other way. Mike T. was right about the install, take your time adn read the instructions and it went very smooth.
F-150 4x4 off road 4.6l
Nerf bars/brush gaurd
K/N filter charger
Flow Master dual exhaust
Eagle cap.
K/N filter charger
Eagle cap.
