Hypertech Chip
Old Oct 11, 2000 | 03:18 PM
mileaux's Avatar
Post
I have been working with Hypertech on a few problems that they were having with a particular chip for a 97 F150 Auto 4.6L 2WD. The program that they have now for me (which I am currently running) is quite impressive. It seems that both Hypertech and Superchips have a problem with the chip staying seated on the service port of the computer. Some folks suggest that you bend the lip up and it will stay others suggest Duct Tape, also a good ides. Hypertech, to the best of my knowledge, is working on a solution for this problem.
My question to you is what type of truck do you have and what kind of performance are you looking for?
Old Oct 11, 2000 | 03:24 PM
JBRIII's Avatar
Post
Thanks for the reply. I have a 97 XLT SC 4.6L 2WD. I have installed a K&N filter and a Gibson Super Truck Cat Back Exhaust.
I'm looking for a little more quickness across the rpm range. More low end push. Better acceleration as well as merging/passing capability. The Gibson seems to have helped with this one.
Any thoughts?
Old Oct 11, 2000 | 03:25 PM
JBRIII's Avatar
Post
Also the chip I ordered is for the calibration 7-48D
Old Oct 11, 2000 | 03:32 PM
mileaux's Avatar
Post
That's the same chip program that I have. I am quite impressed with it. Good throttle response and impressive passing gear shifts. The truck really seems to get mean and wants to really run above 50mph when the O/D is turned off.
Good luck and let me know how it turns out.
KV
'97 F150 SC 4.6L Auto 2WD
Burgandy
Nerf Bars
MagnaFlo single in dual out
Hypertech
K&N replacement filter
Bosch Platinum +4 spark plugs
No track times..yet...
[This message has been edited by mileaux (edited 11-10-2000).]
Old Oct 11, 2000 | 04:23 PM
JBRIII's Avatar
Post
A couple of more questions.
Did you install yourself?
If so how difficult?
Do you use Premium gas?
Any noticable mileafge improvements?
Old Oct 11, 2000 | 05:23 PM
mileaux's Avatar
Post
Yes I installed myself and it is quite easy. Go to http://home.midsouth.rr.com/lightningpage for a full tutorial on how to install the chip, not difficult at all. 30 min including the cleaning of the contacts. Yes you have to use Premium gas..93 octane or higher to avoid pings in the engine. This is only my first tank on the modified program and I haven't done the math on mileage yet. Before on my old program I did see a 1.5 to 2 mpg increase. Not bad for a lead foot.
Later
KV
Burgandy
Nerf Bars
Hypertech Program
Old Oct 11, 2000 | 06:47 PM
ponysix8's Avatar
Post
hypertech goes by calibration number and superchip goes by computer code. who has the advantage??
i plan on getting the hypertech in december.
Old Oct 11, 2000 | 07:08 PM
FrankP's Avatar
Post
Can a Hypertech adjust the speedo, odo, shift points, etc. for larger tires?
Mine is a '98 and I can still change out the tranny 'driven gear' ('99+, all computer controlled), but I really hate to have to put out more dollars for this process. Would love to just have the chip take care of it.
Old Oct 12, 2000 | 12:32 AM
JBRIII's Avatar
Post Hypertech Chip
I am planning on installing the hypertech chip in my truck. I purchased be fore I read avbout all the SuperChippies out there. Does anyone have any experience with hypertech good or bad, things to look/watch out for etc.........
Thanks for your help.
Old Oct 12, 2000 | 08:54 AM
mileaux's Avatar
Post
From what is on Hypertech's website, they have programmers available for the 98 F150's for about $400 bucks. This programmer will enable you to change al lof what you are wanting. I am not sure but I think the chip has a "standard" unless requested when ordering. State what type of mods you have and they can probably adjust the chip program for you if you don't want the programmer. http://www.hypertech-inc.com/cgi-bin...F150&year=1998
Good Luck
KV
Burgandy
Nerf Bars
Hypertech Program
Old Oct 12, 2000 | 08:56 AM
mileaux's Avatar
Post
FrankP:
I believe that both of them essentially have the same programming. I don't have any experience with the SuperChip chip but I am very happy with my Hypertech chip.
KV
Burgandy
Nerf Bars
Hypertech Program
