Hey..Mike T
The R9 is doing great. So, I though I would give you a plug on my website (it's in the sig). I couldn't resist putting in the Boomhauer wave about the sparkplugs just for laughs.
Thanks for all your help and speedy service.
Later,
Chuck
Black 00
http://home.midsouth.rr.com/lightningpage
Later,
Chuck
Black 00
Mike,
I'll make that change about the acetone. That's what I was told by somebody that had instructions from another chip maker. This was before your instructions came.
I always used alcohol for cleaning when I was a tech but I thought maybe they knew something about this application I didn't. I also need to mention the lip on the mounting bracket being a problem.
Later,
Chuck
Black 00
[This message has been edited by LTNBOLT (edited 10-10-2000).]
Later,
Chuck
Black 00
Mike,
How's that look to you. I made sure I put rubbing in front of alcohol. I didn't want Bubba using Jack Daniel's. LOL.
Later,
Chuck
Black 00
Later,
Chuck
Black 00
Hi Chuck,
That was very nice of you, thanks!
Glad to hear you're enjoying the R9 program, it's a real winner on these Lightnings.
I dropped by and just took a quick look at your pics & text for the Splitfire plugs and the Superchip installation, and I have 2 quick comments.....
1.) Thanks for the laughs! Boomhauer's .wav about the plugs is hilarious.
2.) I hate even mentioning this, because you've done such a nice job of these tips for the Superchip installation, so please forgive me. In the Superchip installation text you have there, you mention that acetone can be used to help clean the clear conformal coating from the contacts on the male edge connector. We do not advise the use of *any* kind of solvents, as acetone & others can attack & "melt" the plastic PCB (printed circuit board). Yes, certain solvents, used extremely carefully by those used to handling them, could potentially be used without problems, but the best thing is to not use *any* kind of solvent, and we warn against this in both the manufacturer's installation instructions and in our "tips sheets" that we send out with each Superchip. We do say that we use rubbing alcohol on Q-tips to clean up the connector before & after scraping the contacts, and that's fine to use as we describe, though it will not remove the conformal coating, rubbing alcohol won't "melt" that coating off like other solvents will. I understand your point perfectly well, that the acetone will help to dissolve that conformal coating, and *properly* done that can indeed work well. But as soon as people start doing that in numbers, there will always be somebody or a number of people who will "melt" or damage their board from using too much solvent, or not controlling where it goes, etc., you know how these things can go, so that's why I wanted to mention this, that's all.
I especially liked your pictures and your tips about using the pencil eraser to insure all the coating is off the contacts, that is an excellent technique as you have it pictured there, great advice.
Have fun, & good luck with your Lightning!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Mike Troyer
(540) 862-9515
would Makers,work(hickup)
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
Hoping for deliverance from door crack hell.
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Yes, the rubbing alcohol looks much better than acetone.
Mike Troyer
(540) 862-9515
Mike Troyer
(540) 862-9515
