hopefully last question
Old Aug 27, 2000 | 10:26 PM
split's Avatar
Post hopefully last question
I am resetting my computer now. this maybe a stupid question but are my headlights supposed to be on or in the "on position". Please lemme know asap. Thanks again.
Old Aug 28, 2000 | 04:31 PM
Former Sponsor
Post
Hi Split,
When people are installing their Superchips, or other go-fast parts, we suggest disconnecting the battery to clear the computers memory and allow a fresh program load with the new parts.
Our "technique" for doing this is simple: disconnect the negative battery lead, and then pull the headlights on for about 5 minutes. This will drain all residual voltage from the IC's & capacitors in the computer. After 5 minutes, shut off the headlights and re-connect your battery, and you're all set! This will not drain the battery, by the way, as remember the first thing we did was to disconnect it.
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old Aug 28, 2000 | 07:27 PM
Dustoff's Avatar
Post
I disconnected mine (for my current truck) and turned the headlights on for about 20 minutes. I expected to have to reset the radio..etc..and I discovered I did not. I think it did completely drain the computer though.
I did the same thing for my previous F-150..and everything had to be reset.
Go figure.
2000 F-150 XLT, 4x2, 5.4L Supercab, LEV, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil and filter, Build date 7/00
- Factory cab steps on order
