Superchip & Shift Kit?????
Old Jul 26, 2000 | 03:53 AM
Ryshark5's Avatar
Post Superchip & Shift Kit?????
My Superchip should be here any day now UPS has it scheduled to be here on the 27th. It is for a CPE2 5.4. My question is, can i also get a shift kit and have both the superchip and a shift kit? Does Superchips make one? Also when i regear my truck will it effect the chip at all? I have 3:55lS and will probably have 4:10ls in a few days. Thanks
2000 5.4
3"catback w/flowmaster
Jet FIPK
Superchip(soon)
6"suspension lift
billet grille
tint
viper alarm
Old Jul 26, 2000 | 05:10 AM
Ryshark5's Avatar
Post
When i say shift kit i mean like the programer III thing where a device is in the cab of your truck and you can switch it over to make harder shifts.
Old Jul 26, 2000 | 01:34 PM
Former Sponsor
Post
Hi Ryshark,
What we generally suggest is to use the Superchip for at least a few weeks before deciding that you also want to install one of those electronic shift improvers, like the B&M device, etc.
And yes, there are a number of people who are using both the B&M shift improver or other similar devices in conjunction with the Superchip. Also, some people are running a true shift kit, like the Transgo kit along with their Superchip.
Just so you'll know, over 98% of our customers who install the Superchip do not also use other devices, as they are very happy with what the Superchip does for their shift characteristics. Which is why we generally recommend using the Superchip alone first, to see if you really need more shift firmness.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Info:https://www.f150online.com/rally2000/index.html
[This message has been edited by Superchips_Distributor (edited 07-27-2000).]
Old Jul 26, 2000 | 11:31 PM
Neal's Avatar
Cool
HI!... RYSHARK5 : Forget about those electrical shift improvers, there crap in my opinion and I have heard from mechanics that if set at the "RACE" setting for long periods of time, it can fry internal selenoids inside the tranny. If you want firmer shifts after you install your SUPERCHIP, then do it the right way with a mechanical shift kit like the one I installed from, BAUMANN ENGINEERING . I have a custom SUPERCHIP that the tranny shifting firmness has been cranked up past the stock SUPERCHIP setting and the BAUMANN ENGINEERING shift kit set on stage 5. The truck literly bangs into 2nd gear and chirps the tires all the time. Ocassionally I can even get 3rd gear chirps. By the way you might have a slight problem with the SUPERCHIP/4.10 gear combination. When I first put my 4.10 gears in, I would always hit the rev limiter during the 1st to 2nd gear upshift. Enough to steal 3 tenths from my 1/4 mile times. I called MIKE T. and he helped SUPERCHIP's figure out what the problem was and fixed it. Hope this helps you out.
NEAL [ the horsepower freak ] NEWMAN
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, modified POWERAID spacer, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan. FUTURE MODS : FORD SVT 24LB INJECTORS, BBK 75MM THROTTLE BODY, AADI F1 RAM AIR HOOD, traction bars, and a KENNE BELL BLOWZILLA supercharger.
ESTIMATED H.P TO DATE : 345H.P / 425ft/lbs of torque.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Jul 29, 2000 | 07:40 PM
Flats Man's Avatar
Cool
I also agree with Neal and have both the chip and a valve body shift kit. My favorite mods are the supercharger,chip,and shift kit, in that order.
98 White 4.6 Triton STX Flairside,Class III hitch, Blue Cobra Stripes, Euro Lid by Astro, Bed Rug, Fiero Wing, Air Dam,Westin Step Bars, Ground Force 2-4 Drop,Custom MB Phantom Wheels, Super Chip,Jacobs DIS Ignition, B&M Shift Kit, K&N, Jet coated JBA stainless headers, Magna Flow Muffler with Stainless Duals and of course fully Blown by Magnacharger!
