Mike HELP ME!!!!
Old May 8, 2000 | 01:13 PM
MN99F150-1's Avatar
Unhappy Mike HELP ME!!!!
I want to order the chip for my truck but the problem that I have is that where the sticker that tells me the code is tore off. So how do I know what one it is, I want to order my chip now but I can't. I hope there is different way to do this. So I hope you can help me. thank you
Allan
1999 F150 Bright Red Extended Cab 4x4 Off Road, With Gray Interior, 5.4L, 3.73 Gears,
Add On's for now!
Access Tunnel Cover
Stainless Steel Nerf Bars
Stainless Steel Rocker Pannels
Putco Bed Rails
Clear Turn Signals
Flowmaster Exhaust
Lund Bug Guard
GTS Head Light Covers
Painted Vent Shades
Painted Taillight Covers
Painted X-Cab Covers
K&N A
Red ir Filter W/ Air Box Mod
Stering Wheel Cover
Pionneer CD Deck
Wish List: F1 Ram Air Hood, Tinted Side Windows, Brushguard, Wiper Crawl, Lift W/ 34" M/T Tires, ETC...
Old May 8, 2000 | 04:47 PM
1stSuperCrew's Avatar
Post
The code is also on the computer itself. The 'puter is located above the passenger side kick panel. If I remember correctly, the code is visible from under the hood (where the computer's connecter is attached) behind and slightly below the battery on the firewall.
I'm sure Mike will be along shortly. But I recommend calling him. That way you get you chip sooner
Joe
2001 SuperCrew 4x4 Lariat 5.4/4-spd auto, 3.55 l/s, elec xfer case, Skids, Class III tow, Stock 17"s, Oxford White/Med Graphite leather capts chairs, Rhinolined, SUPERCHIPS equipped
Planned: K&N FIPK (When they get the CARB # for 2001's)
Old May 8, 2000 | 04:50 PM
MN99F150-1's Avatar
Post
I talked to mike today and he was very helpful and I have gotten the chip ordered I can't wait till it's here.
your right it is on the computer it self
thanks all Allan.
Old May 8, 2000 | 09:31 PM
Former Sponsor
Post
Hello again, 1st Super Crew,
Thanks for helping him out, that's what this site is all about, everyone helping in the exchange of relevant info.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
Online Superchip ordering system:https://www.f150online.com/scpp/index.html
Old May 8, 2000 | 09:38 PM
Former Sponsor
Post
Dear MN99F150-1,
I had a good time speaking with you today, I would have loved to have seen your Taurus SHO, that must have been some screamer! Glad to hear you're hanging onto that older straight-8 Olds as well, what a bargain you got! To be able to find an all-original "fat-fender" car like that is very rare and very lucky, to say the least.
Just so others will know, if for some reason your code sticker is missing from the passenger door frame near the door hinges, you can go to a couple other places to look..... you can look under the hood, right behind the battery on the firewall, at the wiring harness as it attaches to the front of the computer. It has a single 10mm bolt head dead-center, and sometimes they will put a white sticker on the wiring harness that has a couple lines of printing onm it, with the computer code.
Also, you can go right to the computer itself, which as 1st SUper Crew described, is on the passenger side inside the cabin, to the right of the dash and just above the passenger kick panel. The computer is held to it's mounting bracket by a black pressure clip, and you simply pull that clip straight off, and look on the back of the computer where the clip was covering up, and there is another code sticker right there. This is on all 1997 & newer F-150's.
Mike Troyer
(540) 862-9515
