Superchips and Comp Cams
Old Nov 11, 1999 | 10:09 AM
T Ellenberger's Avatar
Lightbulb Superchips and Comp Cams
Mike: In one of the many magazines that float through here that Comp Cams was in development on cams for the modular V8's. In the good old days we changed cams and also advanced the ignition for more power.
Maybe you could suggest to the Superchips powers that be to contact Competition Cams to look into a deal with a Superchips and cams package? The article did not say if the cams were being designed for the Mustang or the trucks.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Old Nov 11, 1999 | 02:27 PM
Former Sponsor
Post
Superchips and Competition Cams have *already* been talking to each other, for years now. Superchips also works with numerous other camshaft makers as well, and has for years. As far as making a "package" deal, it all depends on the actual cam specs, as to whether or not a custom program is required. Most cams that are truly designed for computer-controlled engines do not need a custom program, so "packages" are not appropriate in many cases, you see. Most of them don't change overlap & lobe centerline very much, it's primarily more lift, as they have to keep the emissions clean to pass muster for sale in computer controlled vehicles legal for street use. This is just one of many reasons why larger ratio rocker arms are so popular in many engines that they can be used in, as they increase lift without really detrimentally affecting idle quality, etc.
But anyone who changes cams and needs the appropriate programming changes, this can easily be done, just give us a shout.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
[This message has been edited by Superchips_Distributor (edited 11-11-1999).]
Old Nov 11, 1999 | 06:21 PM
Post
Thanks for the response. I love this site for information and an education at the same time.
