Where's the computer????
Old Aug 14, 1999 | 04:14 PM
rbbehemoth's Avatar
Post Where's the computer????
Where is the computer located in the 98 V6 4.2L f-150? Thanks in advance!
Brian
Old Aug 14, 1999 | 05:15 PM
forgeur's Avatar
Post
It's located under the glove compartment on the firewall. Pretty easy to see if you look for a 6"x8" metal box.
Randy
'98 XLT SC, 4.2V6, 4spd Auto, BugflectorII, 50th Aniversery Flooor Mats, K&N Filter, Hard Tonneau Cover, Billet Grill and Insert, Sony CDX-6850 Head Unit, Soundstream Rubicon 405 Amp, JBL GTO 5x7's All 4 Doors, Qlogic 8" sub-enclosure with Kicker Punch XLC Woofer,SuperBrite Bulb Replacements...and More Mods to Come
http://206.170.51.68/truck
Old Aug 14, 1999 | 05:23 PM
rbbehemoth's Avatar
Post
Thanks a lot!
Old Aug 16, 1999 | 02:34 PM
Former Sponsor
Post
On the '97 & up F-150, the computer is mounted on the passenger side, just above the passenger's kick panel. The first inch or so of the computer protrudes thru the firewall, where it connects to its wiring harness. To remove the computer, open the hood, and look right behind the battery at the firewall, and you'll see the computer where it connects to the wiring harness. Loosen (don't remove!) the 10mm bolt that runs from the front of the wiring harness thru to the computer, until you can remove the wiring harness from the front of the computer. Then go into the cabin, and remove the black plastic slide-off clip from the computer, that retains it to it's metal bracket. You can then pull the computer away and out.
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
[This message has been edited by Superchips_Distributor (edited 08-16-1999).]
Old Aug 16, 1999 | 03:03 PM
gaudenti's Avatar
Question
Would I be correct in assuming that the battery should be disconnected before doing any of this?
Danny
'98 F-150 Std., RC, SB, 4x2, 4.2L, 5-sp, 3.08, AC, speed control, rear slider
with Syntec engine oil, MTL trans fluid, Edelbrock shocks, 50 Series Flowmaster, K&N with airbox mod, electric radiator fan
Old Aug 16, 1999 | 04:41 PM
forgeur's Avatar
Post
When we installed mine, we found it 100000000000 times easier to just remove the battery and the battery holder and mount in order to get to the wiring harness on the computer. I would imagine I am one of the few that went so far as to remove it all.
It really made it easy to get the computer in and out. Besides, it's just another saftey precaution to avoid damaging your computer.
Be smart, take the extra time (all of 10 minutes) to remove the battery and have clear access to it all.
Randy
'98 XLT SC, 4.2V6, 4spd Auto, SuperChip, BugflectorII, 50th Aniversery Flooor Mats, K&N Filter, Hard Tonneau Cover, Billet Grill and Insert, Sony CDX-6850 Head Unit, Soundstream Rubicon 405 Amp, JBL GTO 5x7's All 4 Doors, Qlogic 8" sub-enclosure with Kicker Punch XLC Woofer,SuperBrite Bulb Replacements...and More Mods to Come ( If the wife will just agree to them )
[This message has been edited by forgeur (edited 08-16-1999).]
