"New" 1715 Question for Mike
Old Jan 21, 2004 | 11:28 AM
jaymz's Avatar
Mike, I have the "old" 1715 MicroTuner, that I use both fdor my 97 F150 4.6l and for my 2002 Lightning.
What would the benefit be for buying a new model exclusively for the Lightning. I know it wouldn't be for a regular gas program, so what's the advantage?
Thanks,
Old Jan 21, 2004 | 06:50 PM
Former Sponsor
Hi Jim,
Sure, I remember - you use it in the Lightning in summer & your other F-150 in winter - we have a number of people doing exactly that.
The advantage from the current Micro Tuner for the Lightning is if you have added a higher-boost pulley - the current 1715 MT has a custom tune for the Lightnings if it's using a 4 PSI pulley, in addition to the "standard" performance tune for stock boost levels. SO you have 2 different programs for all the factory-supercharged 5.4's in the Lightnings & Harleys, the "standard" tune and then a custom tune for a 4 PSI pulley.
In your non-Lightning F-150, the advantage is you would have 2 *additional* programs (total of 3), one for 87 octane that is towing compatible, then the same program you have now (premium gas towing-compatible, called "tow-perf"), and then another for premium gas that is *not* towing compatible - that's the "max" performance tune, and will get you another 8-10 HP over what the program in your current Micro Tuner will deliver to your non-Lightning F-150.
Nice to see you again, by the way!
Old Jan 25, 2004 | 05:06 AM
black f150 offroad's Avatar
Will the 4# program work with a 2# pulley (on a 03 L), i only have 91 oct gas so i'm looking for a safe route
thanks
