Bypass booster software for diablo chip
Old Jul 20, 2003 | 09:33 PM
tlfwatch's Avatar
Thumbs up Bypass booster software for diablo chip
Can anyone tell me if diablo sport chip has new software program for bypass booster solenoid. for my 2003 lightning i am running diablo chip thanks/:
Old Jul 21, 2003 | 01:51 PM
Former Sponsor
Well, they've never had that to date, so unless somebody just gave it to them in the past few days they don't. And that really doesn't matter much, as that is easily dealt with, and I'd never change chips over that feature.
It's easy enough to defeat the boost dump (which happens a lot less on 2003 Lightnings anyway). Just use the search engine to review the many different posts in the Lightning section on how to do that for free or at very little cost, & you'll find a quick & easy solution.
Good luck!
Old Jul 21, 2003 | 04:49 PM
tlfwatch's Avatar
Wink Thanks mike
Thanks mike
Your help and advise i am most grateful as on most of these issues i am not to well school i am glad that you give you time and emails to help us on these lightnings thanks again mike as this is my first lightning.
Old Jul 22, 2003 | 11:31 AM
Former Sponsor
You're very welcome!
And congrats on your new 2003 SVT Lightning, you've got a great vehicle that is capable of *much* higher performance levels, should you decide to take it further. They can easily be taken into the 12's, and even as far as into the 11's (in the 1/4 mile) on the stock motor with mostly bolt-on parts.
We actually sell a "boost bypass kit" for those vehicles, but frankly, we have had virtually zero problems with 2003 Lightnings dumping boost like with the 99-02 Lightnings. That whole system is still there of course, but there are some changes to it in the 2003 Lightnings that seem to have almost eliminated this as a concern.
This issue of dumping boost is primarily one that happens in these Lightnings if you do a long smoky burnout (you can do 1, but not 2, and if you do a burnout you may well dump boost and run a 15-second 1/4 mile), or if you have raised the boost significantly with pulleys, then they tend to dump boost on the WOT (wide-open throttle) 1-2 upshift. We see very little of this on 2003 Lightnings that we've modified to run in the 11's, for example. That being said, I'd go ahead and take care of it just n case, especially if you intend to take it to the track.
Have fun,
Old Jul 25, 2003 | 05:07 PM
kpayne's Avatar
Patrick S. with Diablo has been doing it since 1999. All a dealer has to do is ask for it in a code. Its typically not done because its a safety measure to not disable it. Only those with Lighting Diablo chip experience know this.
Old Jul 25, 2003 | 10:47 PM
tlfwatch's Avatar
Talking And i thought this was something new
Well mabey my diablo chip already has the program already programed in it
