2000 Grit Sandpaper marks
Old Oct 8, 2002 | 05:20 PM
wedgewoodblue00's Avatar
What product should I use with my Dewalt buffer to remove 2000 and 1500 grit sandpaper marks. I thought I got them but after a day or two the marks showed up again. I used meguiars (i believe medium cut, on the bottle it goes to 4 or 5 on there scale) I tried there fine cut and didn't work and neither did this. I'm using the pad that the local shop recommended and there still there. Not as noticable but still there. Any suggestions, I didn't know if I should go up one more step with the meguiars heavy cut cleaner or not.
Old Oct 8, 2002 | 05:29 PM
Intel486's Avatar
You have the DW443, correct?
Use a cutting bad. Like a yellow foam pad w/ open cells. Then just work a product over the area at full speed and apply some pressure to it. The Dw443 will remove them but not as quickly as a rotary. It will probably take two or three applications really working the product over the area.
What products do you have?
I'd suggest Pro's P-11 Creamy Cutter but there is probably something easier for you to get.
Old Oct 8, 2002 | 05:55 PM
I have Meguiars #2 Fine Cut Cleaner and Meguiars #9 Swirl Remover will these work or will I need something stronger. I wasn't applying much pressure while doing this. How much should I use. Before you say alot, I'm 6'8" 350 so alot to me might burn the paint jk.
