Buffer: How to info
answer
Go to the following website and watch the video. They're using a PC, but the concept is exactly the same.
http://www.meguiars.com/clinics/clinics_template.cfm
It is pretty easy.
First find an electical plug in... ermm let me skip a few steps.
I like to put a few strips of polish across the section. I then smear it around the section with the buffer pad without the buffer being on. I then start it on the lowest speed and spread it around the section. I then crank it up to the highest setting and proceed to work the area. I go side to side, diagonal, and then up and down. I then buff the residue off.
For apply wax just keep it on the lowest section. Put a few stripes on a section and then use the lowest speed to spread it evenly.
