Black Streaks from Weather Stripping
2001 F-150 Supercab in Wedgewood Blue has those ugly blackish run marks from the small rear windows after it rains. I use Zaino products but these "runs" are getting more difficult to remove. I'm considering removing the rear windows, cleaning the area with a good solvent, then use a 50 year clear silcone caulk to seal the black weather strip. Anyone got a better idea?
JR
2001 f150 Wedgewood Blue, 4.6L, Auto.
Sportsmaster bed cover
Ravin z-55 si/so
K&N with homemade air induction
JR
Ravin z-55 si/so
It is dirt washing out of that window. I use to have the same problem. Now I make sure I run my wash mit around the window when I wash my truck. I then also make sure I dry it out very well. I'll open the window and stick a towel in there and make sure I dried all the water out.
I haven't had a problem since I started doing it.
I wouldn't seal the window shut though...
Streaks from windows
I've had my '97 since it was new, it now has 114,000 miles on it. It is Moonlight blue and has the streaks beneath the rear side windows whenever it rains. So far wax has removed it without problems. I assumed that all the supercabs had this problem but it just shows up most on certain colors.
Re: Streaks from windows
When I had them I use Pinnacle Paint Cleansing Lotion and it removed them quickly. Just dry around that windows after you wash and you'll never get them again. My truck is deep wedgewood blue and I haven't gotten them since I started doing that.
