Dirt and tires!!
Old Feb 29, 2012 | 08:11 PM
whitten1823's Avatar
Dirt and tires!!
Anyone have a tip on how to get dirt that seems to be soaked into the tire, cleaned off?? Pressure washing does nothing.
Old Feb 29, 2012 | 09:07 PM
SSCULLY's Avatar
I would say your APC of choice diluted to the recommended level for tires with a stiff gong brush for a 1st pass.
If that does not work, go slight stronger and try again with the brush.
both times, make sure to rinse it well, in addition to the surrounding areas.
Old Feb 29, 2012 | 09:18 PM
worm5932's Avatar
bleach white always works for me
Old Mar 1, 2012 | 09:09 AM
dixie_boysles's Avatar
X2, let it soak a little bit and once you clean super good, stay away from Tire shine.
Old Mar 1, 2012 | 01:14 PM
If you use bleche-white, keep it OFF the wheels. A pH-neutral APC is a lot safer.
Old Mar 23, 2012 | 02:10 AM
Tuttled's Avatar
diluted purple power, spray on, let it sit a few minutes, brush it dipping the brush in warm water, rinse, enjoy
Old Apr 1, 2012 | 09:28 PM
bansheerider's Avatar
Simple Green has worked well for me. Spray on, agitate with a brush and spray off. Another good product is Meguiars Hot Rims all wheel cleaner. Make sure you follow the directions on the bottle because using the wrong Hot Rims cleaner can cause more issues in the future.
Old Apr 2, 2012 | 11:59 AM
Hot Rims to clean TIRES?
Old Apr 2, 2012 | 01:23 PM
Yes, it's a rim and tire cleaner.......
http://www.meguiarsdirect.com/product_detail.do?q=4630
Old Apr 2, 2012 | 01:29 PM
Old Apr 2, 2012 | 04:22 PM
Old Apr 2, 2012 | 04:23 PM
Sorry for the triple posts, geez! My phone was messing up.
