Smudge on headliner what cleaner ?
Old Sep 16, 2011 | 08:35 AM
honestlarry's Avatar
I have a smudge on the headliner, on edge above front driver side,what cleaner do i use or the best way to clean.
Old Sep 16, 2011 | 08:41 AM
Nick@Autogeek's Avatar
Former Sponsor
Stoner Upholstery & Carpet Cleaner works very well. To clean a headliner, I generally spray the cleaner on a microfiber towel and pat the surface. You want to avoid brushes or rubbing because it might cause the headliner to fray.
Old Sep 16, 2011 | 09:03 AM
smudge
Thanks, i will try the stoners being careful not to make it worse.
after applying do you light vaccum or just patting. thanks
Old Sep 16, 2011 | 02:29 PM
Gipraw's Avatar
I just use a MF towel, then a dry one to go back over the area and blend it in with the surrounding area.
If you use a vacuum, be careful, as the strength of the vacuum can damage the headliner.
Old Sep 16, 2011 | 03:53 PM
Former Sponsor
Old Sep 16, 2011 | 08:24 PM
JMemmer77's Avatar
Shout Wipes work pretty well..... I keep some in my truck just in case something happens.
