Water spots. How do you get rid of them?
Old May 18, 2001 | 03:07 PM
steveo's Avatar
Post Water spots. How do you get rid of them?
Does anybody know how to get rid of water spots. Tried claybar and Zaino, still no luck. Does anybody know how to remove them. -steve
Dedicated to Dale Earnhardt, Gone but not Forgotten......
  • -1999 Ford F-150 Supercab Flareside ORP
  • -4.6 Liter V-8, Auto, 3.55 LS Rear
  • -Deep Wedgewood Blue
  • -Flowmaster Delta Flow Series 40 single 2.5" inlet w/dual 2.5" outlets
  • -Two 18" Adcar Stainless Steel Exhaust Tips
  • -Airforce 1 Performance Intake
  • -Lund Lighted Moon Visor (painted)
  • -Lund Interceptor Bug Guard (painted)
  • -Deflecta-Shield Window Rain Guards (painted)
  • -Delecta-Shield Slotted Tail Light Covers (painted)
  • -Manik Grille Guard
  • -Ford Factory Cab Steps
  • -Extang Soft Bed Cover
  • -Ford Lighted Ovals Front and Back
  • -Tinted Windows (5% totally illegal)
  • -Pioneer P725R CD Player w/Flip Face Head Unit
  • -Superwhite Headlight Bulbs (from Online Store)
  • -K&N Air Filter
  • -Air Box Silencer Removed
  • -Tail Light Modification
  • -Lots of Blue Wire Loom Under Hood
  • -Cranked Torsion Bars to Level Truck Out
In Loving Memory of Craig W. Menth Sr.
http://njf150truckclub.homestead.com/index.html
www.my-f150.com/steveo
steveo@f150fanatic.com
Old May 19, 2001 | 08:02 AM
XceLenT Driver's Avatar
Post
steveo,
This discussion is as old as water itself! But there are two types of "spots". The first is the result of deposits left on the surface of your paint, the second is the result of something etching (removing) the surface of your paint (clearcoat). Go inspect your paint with a magnifying glass to see which it is. If they are deposits, then you should be able to clean or rub them out eventually. If they are the result of etching, then it will be more difficult if not impossible to REMOVE them as they are an artifact of the paint.
XLT_D
Old May 19, 2001 | 08:46 AM
Tampa-Harley's Avatar
Post
water spots can be removed
etching in the paint can be removed by wet sanding the very top surface of the paint. I recommend having a pro do this. useing your fingers on the sand paper will result in a uneven surface, its recommended to use the palm of your hand. I dont do it my self, as a mater of fact I have a 2000 Harley Davidson F-150 with alot of etching on the hood and I do not intend to on removing it for some time now. (also have web cracking in the channel on the roof and would rather leave the it there then have any shop repaint my truck, I would rather take the hit on resale then have the truck repainted)
Old May 20, 2001 | 08:30 PM
WYSIWYG's Avatar
Post
Check out www.autopia-carcare.com.
Good tips for removing water spots.
However, if the spots have etched the clearcoat, then you need to seek professional assistance.
Old May 21, 2001 | 02:21 AM
steveo's Avatar
Post
Well I guess that I just had some surface contamination. I tried this wax called "the wax shop wax" and it took the spots right out/off. I use zaino but this stuff seemed to do a better job in a quarter of the time. Thanks for the help -steve
  • -K&N Air Filter
