Shorter Antenna????
Old Jan 12, 2001 | 10:20 PM
XceLenT Driver's Avatar
Post
The "factory" antennas are approximately 30-31" long. That works out to be about 1/4 wavelength of the the FM band (88-108 MHz). Phsically shorter antennas will likely have the active portion wound around a mast or include a coil "loaded" base. This compensates for the shorter length. Cutting (or shortening) the antenna will essentially shift its tuning to a higher frequency. This will result in decreased reception. Aftermarket radios usually have greater sensitivity and are more likely to "tolerate" a mis-tuned antenna. If you live close to your favorite FM stations or listen to AM you won't notice much difference.
Y2K Oxford White XLT S.C., V6, Auto, FoMoCo Mud Flaps, Lund Bugflector, Tinted windows, Auxillary BU lights, 2x55W DRL, UNGO Keyless entry, FoMoCo/Duraliner bedliner
Old Jan 28, 2001 | 09:21 PM
LARIAT1's Avatar
From: INDIANA,.....USA " Where more than Corn grows in Indiana"!!!
Thumbs up
I have to the in the pic in the above post. It Trenz #3 I can`t tell any differance from the stock Antenna. I love it & it doesn`t hit the garage door either!!!!
Lariat#1
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC.....
ORP & Tow Package Complete Lariat Option Package
{APPEARANCE}
GTS Projector Beam /Carbon Fiber Headlight Covers
AVS Tail Lights Slots
Door Sill Protectors
Flareside tail lights wired to work upper & lower lenses together
Owens Fiberglass Step Boards
Custom Tinted Windows
Ford 2-Piece Bra
Lighted Ford Logo in Grill
20" Chrome Exhaust Tips
A.R.E Bed Cover Lid
Pendaliner Inner Tail Gate Protector
Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection
Lariat #1 Plate under glass on Front Bumper
Custom made Ford Red Window Decals
Blue Tinted Rear Lic. Plate Protector
Ford Lited Hitch Receiver Cover that works off brakes lights
Heavy Duty Bed Mat
Red reflectors above Rear Bumper
{PERFORMANCE}
4.6L WINDSOR
Auto Trans
3.55 LS
4-Wheel ABS
Platinum 3 Spark Plugs
K&N Air Filter W/ modified stock MAF side air box
Outerwears Blue Pre-Filter Cover
Tornado Air Man.
Perma-Cool Oil Filter Relocation Kit
Motorcraft Racing Oil Filter FL-1HP
Fumoto Oil Drain Valve F-106
Dual Exhaust System W/Stock Muffler
NAPA Ceramix Carbon Ceramic Premuim Brake Pads(Front)
17" Goodyear Wrangler A/TS Tires
55 Watt Halogen(replacement) Reverse Lights
Pilot 55 watt Halogen (add-on) Reverse Lights on Hitch under truck
Driving Lamps upgraded to 55 Watt Cool Blue Halogen Bulbs
Pilot Bright Whites headlite bulb replacements 65/55 watts
Driving Lamps(Foglites) work W/ High Beams On & Driving Lamps(Foglites) also work (ON or OFF) W/ Park Lamps On W/Switched Relay
A.R.E Cover wired W/interior(dome) light wired to a mounted door jam switch thats wired to hood light
SurgeGuard by Calterm
{AUDIO} Stock In-Dash Cass. W/6 Disc Changer & 2 Stock Speakers(back)
2 Pioneer TS-A6865 3- Ways(front)
Black Felted Inner Front Door Speaker openings All Speakers Dynomat Lined
Trenz Billet #3 Antenna
{SECURITY}
Ford Total Security System W/ Motion Alarm All on factory Key Fob
Ford Warning Decals on Windows
A.R.E Cover & Hood also wired to Alarm System Hitch Pin locking system
This is LARIAT#1..... IN The Great State Of Indiana "Where more than corn grows in Indiana".
........http://hometown.aol.com/terrylariat1...page/auto.html A Very Proud Member of ...www.f150online.com
Future Mod.`s.......
Soon to have Flareside Rear Step Bumper re-plated (Triple Chrome Plated)
Old Feb 15, 2001 | 01:31 AM
4ord_man's Avatar
Post
I have had my billet antenna on for almost three years, no problems
Old Feb 15, 2001 | 01:29 PM
Caliendo's Avatar
Post
My stock antenna is about 33" and hits the door very nicely. I bought the 18" plastic whip antenna from Walmart, but it looks bad on a truck. Then I got one from RadioShack that was 28". It doesnt hit the door as bad, although, it does fly around like a piece of spagetti in the wind when im on the highway (very flexible!!). I'm gonna cut the original and put a lead weight on the end and be done with it!
Old Feb 15, 2001 | 01:40 PM
Casper II's Avatar
Post
I did the same as many of you.... cut the top 3 inches or so and left it at that. No radio reception problems. I could not get the small ball off the cut off part to finish the end so it looked a little 'naked'. I went to Advanced Auto and bought one that has 6 or 7 coils in the mast about half way up and stands about 18 inches tall. Cost $4.99. It's made of stainless steel painted black. Works for me. Not weak in the wind either.
2000 Flareside SCab 4x4, 5.4 w/3:55, Oxford w/gray leather captain's, upgraded Lariat pkg, Class III towing pkg, all power, monogramed dash cover, fog+high beam mod, expy console, billet third brake light cover, K&N, custom exhaust (single in-dual out) with Flowmaster 40, Superchipped. Hellwig bar is next.
