What to do about chipped paint
Old Jun 7, 2000 | 02:11 PM
psykoprobe's Avatar
Post
I bought some Ford touch up paint and it matches perectly and is a stong enamel. My
neighbors dog jumped on the side of my Y2k
and put 8 18" scrathes down my passenger
side door. so this stuff works good. about 8 bucks a bottle.
Old Jun 8, 2000 | 12:15 AM
Freezer's Avatar
Question What to do about chipped paint
The other day I was driving down the freeway when some vehicle ahead of me kicked up a small pebble which came down on top of my cab. Made a fairly loud noise and scared the heck out of me. When I got home I looked on top to see a small paint chip where it hit. Now my question is, what is the best course of action here. I don't care so much about getting it fixed, after all it's on top of the cab, plus it is small. But I don't want rust to form on the exposed metal, nor do I want this to be the starting point for the paint around it to peel off. Any one got some good advise?
1999 Lariat SuperCab Flareside, Amazon Green with Silver trim, 5.4L, 4x2, 4 wheel disc/ABS, 3.55 limited slip, towing package, fog lamps, sliding rear window, captains chairs, keyless entry with alarm, spray-on bed liner, bug guard, and K&N. http://www.csc.calpoly.edu/~bfriesen/truck.html
Old Jun 16, 2000 | 03:07 AM
F150grl's Avatar
Post
Try taking it to the dealer it just might be covered under warranty. I had a chip on the roof,and they are going to repain it. Check it out. What can you loose.
[This message has been edited by F150grl (edited 06-16-2000).]
Old Jun 16, 2000 | 01:35 PM
max mitchell's Avatar
Lightbulb
The touch-up will not last as long as the factory paint, so check it periodically to add more touch up paint. This will keep it sealed from the elements, and prevent rust.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
4-wheel disc/ABS,Chestnut/Parchment,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
Old Jun 17, 2000 | 12:23 AM
Freezer's Avatar
Post
To be honest, I would have a hard time asking a dealer to fix that under warrantee. Even if they would, I couldn't justify it to myself. After all there was nothing wrong with the manufacturing. However, I did pickup a little bottle of the touch-up paint ($7) and touched up the spot. To be honest, the paint color matched exactly. The only way I can see anything happened was because the paint isn't perfectly smooth there, there's a little bump. But if I really wanted, some super-fine sandpaper would take care of that. But since it's on top of the cab, I don't care.
