How is da usefull
Old Apr 12, 2010 | 11:09 PM
waloro1's Avatar
How is da usefull
I have a Makita polisher that I use on a regular basis with good success, but was wondering what is the difference between this and the DA you guys often chat about.
Also would like tips on how to use a DA.
Old Apr 13, 2010 | 03:33 AM
ELVATO's Avatar
There's less of a chance to burn through your clear.
A rotary works a lot faster, though, which is good if you are a pro since you can get more cars done. Also, I hear you can only really burnish/jewel paint with a rotary....
Old Apr 13, 2010 | 07:16 AM
2stroked's Avatar
Before I jump to any conclusions, is your "Makita polisher" a rotary buffer or a random orbit polisher? There's a big difference there.
Old Apr 16, 2010 | 10:23 PM
roushstage2's Avatar
Originally Posted by ELVATO
There's no chance to burn through your clear.
Fixed.
Old Apr 17, 2010 | 01:29 AM
ELVATO's Avatar
I'm sure I could burn through some clear with a Flex
Granted, he's probably referring to the G110/100 type of DA.
Old Apr 17, 2010 | 05:46 AM
I want a Flex...it probably won't happen for a LONG time though since my G100A is still going strong, which would be replaced for free.
Old Apr 18, 2010 | 01:19 PM
Gipraw's Avatar
there are plenty of reasons to have both a DA and a Flex ..
if you don't want to spend the money, that is one thing and is understandable, but the two tools have very little overlap, and you would use them both if you had them.
I actually have 2 DA's. A Flex DA, and 2 rotaries. I use them all, sometimes on the same vehicle.
Old Apr 18, 2010 | 03:29 PM
Old Dogg™'s Avatar
X2
The Flex has one backing plate size so it's limited to the areas you can use it in unless you start angling the pad and in my arsenal it's the big gun or my fast tool if I have the space. I also have a G110 and a G110V2 and they get used more often than the Flex because sometimes I just dont need the torque...or the weight to get the job done.
After you correct your paint and properly take care of it, there is no need for continual aggressive methods IMHO.
Old Apr 18, 2010 | 03:38 PM
pmason718's Avatar
I have a Flex and a G110 also. I'm going to use my G110 more now for the smaller pads in smaller areas.
Old Apr 19, 2010 | 04:32 AM
I'll just have to see about it I guess down the road after I get some other stuff taken care of. I keep seeing things about the Flex, and I wish I had it! lol
Old Apr 20, 2010 | 11:24 PM
RollingRock's Avatar
X3....have the same number of machines. Like OldDogg, I use my DA with 3" pads and my Flex for 98% of the work and my two rotarys's, well they are there for JIC.
The.....RollingRock.
