'winterization...what are you doing?'
Old Nov 3, 1999 | 10:32 AM
Andthensometoo's Avatar
Post 'winterization...what are you doing?'
Help me! I'm at it again, only this time I'm calling it "winterization" instead of "modification" This consisted of Polished steel fenderwell moldings, * new custom mud flaps, undercoating anything I didn't get to this summer, and sealing screw holes from the added on stuff ect. Here in MI the snow started yesterday and that was the day I finally had all the stuff I needed to do this. Even though the snow was melting as it came down, to emulate rain, it was still snow in the air and I wasn't going to let that stop me. Noooo! I just had to do it. The day before I had a "false start" as it were. That's when you start something and failing to forsee screw ups, don't get extra parts, as well as deciding to change some *parts(see above). I did accomplish one thing however, I took apart the tailgate and lilthium greased every moving part to avoid last years "frozen/stuck tailgate" problem. So I try again after buying extra extra parts. It happens MY garage is full of crap and so is my freinds, but she also has a carport, so I asked if I can come over. They (her and her sister) already suspect I'm crazy, and know to just "let me have my way" so I haul all of my tools and some of my buddys over there and in the snow/rain procede to put those Gosh-darn-things on, taking special care to follow the "mental notes" from the day before. Including 1) Use LITTLE pieces of 3M tape to hold molding while drilling instead of the whole piece. 2) Then remove, wasting only the little pieces and put big piece on running the length of the whole molding. 3) Caulk the whole edge where the drilled holes are and pull back 3" of the 3M tape backing leaving it sticking out. 4) Put on molding carefully lining up holes and then pull the tape backing tab out while pressing the molding on. Then screw in the screws. 5) Wipe off ooozing caulk BEFORE sticking your head under there to check for screw penitration.
I now have some added mental notes for the mudflap application. 1) Instead of spending three hours trying to do this without removing wheels, spend 10 minutes removing wheels. I'm glad I had enough forsight to bring my super duper scratchless clamps. 2) Clamp mud flap on 3) Drill 4) use 10mm bolt "feature" of the screws to avoid changing the drill bit while hoping flap doesn't move because of the 40mph wind! Also make sure to bring extra WARM clothing. I had to barrow Cindy's, but fortunately, wears the same kind of stuff as me when working outside.(insulated flannel over sweatshirt, what a Gal! -Available too) End result: five hours to do the drivers side rear wheel, one hour to do the passenger side rear wheel, including cleanup and putting tools away. It's now 9:00pm and I don't even know what this will look like when the sun comes up. Now I just have to do the front! I think I might give my self a couple of days to recover, however. As a final note: wait until the silicon caulk has dried before trying to remove it from hair, it will only spread it around. Lather, rinse, repeat, repeat, repeat. Oh Oh, I think I just found a gray hair!
So, just what are you other Northerers doing?
"Moonlight Blue" 98 F150 SC XLT 2WD 4.6, 3.55 LS Tow Pkg. SUPERCHIP, K&N Airbox mod. w/ "Cool" intake, Mobil One Oil, Bosch +4's. Lund Fastback, Lighted visor, Runninng Boards, Crome Taillight covers, Smoked Bug and Rain guards, Shelf-it, Carpet dash cover, Red Wings license plate in front, Red Wings license plate frame in back, Little Detroit Viper hanging from mirror, Oh yeah, and one "Blacked-out" grill
LOOK-OUT! Can't jump curbs anymore RB's make it look lowered! http://www.fortunecity.com/silverstone/daytona/843/
Old Nov 3, 1999 | 10:58 AM
ford-tough1's Avatar
Post
For winter, well I guess will extend the vent hoses on everything, and run them in the cab for deep water crossings while hunting. Thats it. No snow down here.
1997 4x4 5.4 ORP XLT extended cab Dark Toreador red Westin nerf bars tint HARDER THAN A ROCK AND FASTER THAN A HEART BEAT
Old Nov 3, 1999 | 11:05 AM
btr's Avatar
btr
Post
A good wax job and if you don't already have one, build a garage!
1998 F-150 SC 4X4, 5.4, ORP, Red clearcoat, K&N, Chrome push guard, roll bar & tube side steps, Smoke bug guard and tail light covers, Black bed mat & Ford mud flaps.
www.wrtc.com/oldbook/Truck5.jpg
Old Nov 3, 1999 | 11:10 AM
cphilip's Avatar
Post
Move South!
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels and the 4X4 decals, MODs so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps.
Old Nov 3, 1999 | 02:04 PM
Post
Tina I too have a spare. It is a rain jacket with fleece lining, extra big so I can wear it over any clothes I have on,and it's always tucked under the seat year round. However due to the close clearance between my Truck and the side of the garage, I needed something 'soft' so as not to scratch the Truck in case I brushed up against it.
Old Nov 3, 1999 | 02:28 PM
cphilip's Avatar
Post
Yesterday? OK Tina. Be truthfull now. What the temperature with wind chill today! BTW, Its about 60 sunny degrees here in upstate SC just a slight breeze. Ain't it great!
Old Nov 3, 1999 | 05:59 PM
Pastmaster's Avatar
Post
I will put a piece of cardboard in front of the radiator and pulling the block heater cord out of its "summer" hibernation
Old Nov 3, 1999 | 07:47 PM
JA_Stang86's Avatar
Cool
Over here in WI we get just as much salt and snow. Since I opted for the 4X2 I parked it in the garage next to my motorcycle and will drive my beater Mustang for the next few months.
Jeff
1999 F150 Lariat
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield, VentVisors, Class III hitch, Ford molded mud guards, soft tonneau, factory CD with changer (thanks Dusty), tinted windows
Menasha, WI
http://www.fortunecity.com/silversto...ton54home.html
Old Nov 3, 1999 | 08:12 PM
Ron Kaltenbach's Avatar
Post
Will be doing nothing - Today it was 85 here in the Southern California desert (near Palm Springs).
99 XLT 4X4 Reg Cab, Sport Package, 4.2 with 5 speed, 265/70/17 tires, 3.55 axle, 4 wheel discs and 4 wheel ABS, K&N air filter, a Dynamax Race Magnum muffler and a Kenwood CD stereo system.
Old Nov 4, 1999 | 12:43 AM
Tina's Avatar
Talking
Yesterday it was 80 degrees here For winter, I make sure I have a spare jacket in the truck
Old Nov 4, 1999 | 08:35 AM
Tina's Avatar
Cool
What's with this weather??? I post 80 degrees and a couple of days later the bottom falls out. It must be about 36 degrees out there right now. But by the weekend it should be back up in the 70's Andthensometoo is this your fault for "winterizing" your truck??? Gee, I hope I don't have to!!
Old Nov 4, 1999 | 09:31 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Post
I check the tire air pressure more frequently in the winter.
I gave it a good wax job to get me through to better weather.
Oh yeah, and I put a bra on.
Old Nov 4, 1999 | 10:24 AM
cphilip's Avatar
Post
One of those pointy Viking ones? Must be cold in the winter!
[This message has been edited by cphilip (edited 11-04-1999).]
Old Nov 4, 1999 | 01:09 PM
HCBPH's Avatar
Post
I'm doing the same thing as every other year. Had the truck Ziebarted when I bought it. Wash out the underside of all the accumulation. Washed and waxed the body. Change the oil, check the transmission fluid. Check the battery fluid level & condition of the cables. Check the antifreeze is good to at least -30. Insure all the lights are working properly. Get the snow tires (and winter rims) on and the bags of sand and shovel in the back of the truck. Make sure the snowblower runs and has plenty of fuel.
Now you can build the fire in the livingroom - RATS - forgot we don't have a fireplace. Guess I'll just have to pull on an extra blanket till spring finally arrives.
[This message has been edited by HCBPH (edited 11-04-1999).]
Old Nov 4, 1999 | 02:33 PM
cphilip's Avatar
Post
Stocking up on Ruby Port, Dewars Scotch, fine Dominican Cigars and beer making kits.
