Bugs
Old Mar 12, 2010 | 09:48 PM
shrek06's Avatar
Bugs
I know there have been many discussions on this.. from what wax to use, wax many layers, spray on protectors... etc.
What if when I put NXT on just the front a little thick and just left it? It would look like hell but then on the other end of my 16 hour drive (which will most likely be through the night) I can just wipe it off.
bad idea?
Old Mar 12, 2010 | 10:05 PM
2veloce's Avatar
Have you thought about
http://www.stylintrucks.com/parts.as...tfamilyid=5667
Old Mar 12, 2010 | 10:47 PM
ian51279's Avatar
Trust me, you don't want to put on NXT "a little thick". You'll kick yourself when trying to remove it.
Just put a fresh coat or two on and remove it. Next time you wash use a dryer sheet and the bugs will just fall off.
Old Mar 13, 2010 | 02:55 AM
I use Seafoam Bugs B Gone then wash and rewax it.
Old Mar 13, 2010 | 08:23 AM
shrek06's Avatar
Thanks everyone... what's magical about the dryer sheet? Just that it is soft?
As for NXT, I didn't think it would be that hard to take off.. but I will take your word for it and NOT do that.
I didn't know seafoam made a bug remover. Where do you get it? Or do I just need to order it online?
I am a believer of seafoam. I had a Honda that had a power steering that was hard has hell to turn when cold. I put a little of that in the oil.. and haven't had problems for years...
Old Mar 13, 2010 | 08:26 AM
shrek06's Avatar
Bugs
Originally Posted by 2veloce
Is this covering the paint above the bumper as well. I have never have used one of these as I am "paranoid" that it will scratch the paint, with the ever so slight vibration from wind.
Old Mar 13, 2010 | 12:32 PM
I bought it at Advance Auto, also check Ace Hardware, O'Reilly, Autozone, Carquest, Pep Boys, and Napa. Spray it on, let it sit for about a minute, then wash.
http://www.seafoamsales.com/bugs-b-gone.html
For a real easy rewax (the Bugs B Gone removes wax) you can use the new Meguiars Ultimate Spray Wax. Wallyworld carries it. It has the same polymers as NXT and it's a wipe on wipe off product.
