I need help with cleaning my Pads!
Old Apr 20, 2009 | 04:34 PM
jfarris05's Avatar
you guys have any suggestions for cleaning my DA pads? I have only used them once and that was at the end of last summer. I searched the forums and couldnt find anything for some reason. I know I have read some stuff on here before. Anyway, any help will be appreciated
Old Apr 20, 2009 | 04:47 PM
05supercrew's Avatar
I through mine in the sink with hot water and Dawn dish soap and let them sit for 1/2 hr. Then fold the pad in 1/2 and squeeze the dirt out, I repeat until clean. Leaving it in a bucket over night works even better. After that some times I will put the pad back on the DA and spin some of the excess water out.
Old Apr 20, 2009 | 04:50 PM
dsq3973's Avatar
I soak mine in the sink with hot water and Dawn dish soap over night and then rinse them out in the morning with the hottest water that I can stand to have my hands in. You may have to do this a couple of times if there is dried probuct on them. There is a pad cleaner made by Pinnacle that some of the guys here use and get good results with and it can be found at AutoGeek.com. Hope this helps.
Old Apr 20, 2009 | 05:28 PM
ibcop's Avatar
AutoGeek is having a sale on the Pennicle Pad Cleaner - buy one- get one free!
http://www.autogeek.net/xmt-pad-cleaner.html
Get a pad brush while your'e there and you'll b good to go.
http://www.autogeek.net/padtool.html
Old Apr 20, 2009 | 07:02 PM
jfarris05's Avatar
thanks guys... I'll get right on it and hopefully i'll be ready to give her a good detail on Thursday.
Old Apr 20, 2009 | 07:30 PM
Murphy's Oil Soap works good too.
Old Apr 20, 2009 | 09:47 PM
Gipraw's Avatar
Old Apr 26, 2009 | 09:53 AM
last5oh_302's Avatar
For those using Murphy Oil Soap, how much of it do you dilute with water?
A cap or two in a gallon?
Does it really clean the polish off the pads that well?
I used Simple green (about a cap full for a gallon of water) and let the pads soak for about half an hour. It semed to do a decent job but I still had to work the pads by hand to get a majority of the product out of the foam.
Old Apr 26, 2009 | 10:02 AM
NCSU_05_FX4's Avatar
X3! Awesome!
Before:
After:
- NCSU
Old Apr 26, 2009 | 10:05 AM
Wow! Thanks NCSU! That really helps
Old Apr 26, 2009 | 10:09 AM
I just poured a little bit soap on the pad and washed it under warm running water. If it wasn't all clean, I'd repeat until it was. Murphy's doesn't dissolve the polish/wax/etc, I still had to work alot of it out with my hands.
- NCSU
Old Apr 26, 2009 | 10:10 AM
BTW, that clean pad looks a lot better than my clean pads, NCSU.
Old Apr 26, 2009 | 10:11 AM
- NCSU
Awesome, thanks. That really did work well.
Old Apr 26, 2009 | 10:16 AM
No prob. Now I just have to wait for the pollen season to end here...
Then I can get out and give the truck a full detail it so badly needs!
- NCSU
Old Apr 26, 2009 | 10:31 AM
- NCSU
Ha! Yeah, that pollen is a major PIA. We haven't quite hit that point up here yet, but I'll be doing a serious detail tomorrow before heading up north (where pollen season happens even later in the season) where I spend a good portion of my summers. I park under trees and that yellow stuff really covers everything. At least by detailing/sealing the paint now the pollen will come off easier.
