I Finally Bought a Porter Cable Polisher
Old Mar 23, 2009 | 09:30 PM
last5oh_302's Avatar
After all these years of polishing by hand I finally bought a polisher. I've wanted one for years. I'm a lazy **** and polishing by hand is one hell of a lot of work. This polisher should take a majority of the labour out of the picture and have much better results.
As mentioned, I'm lazy, so I'll be using the same "all in one" that did so well for me by hand. Poli-Seal and a Green Lake Country pad should do the trick. For all you OC 'ers, I realize I won't get a "car show" shine, but the shine this stuff provides is still a very good shine and I'm satisfied with the results provided by hand. Plus Opti Seal will correct, and seal all at once! That's perfect for a lazy fock like me
Anyway, just thought I'd share, because I'm kinda excited to use this thing.
Old Mar 23, 2009 | 09:37 PM
pmason718's Avatar
sweeet. I have G110 and I attended a Megs class this past weekend in Fl with Mike Phillips and I had a blast. I learned so much and I can't wait for it to warm up here in NYC so I can use it.
Old Mar 23, 2009 | 09:44 PM
esf's Avatar
esf
Probably just a typo but thought I would point it out incase anyone else sees it and assumes opti seal will correct. Pretty sure you meant poli seal both times.
Old Mar 23, 2009 | 09:50 PM
Yeah, I just bought it and it will take some time to arrive, but that's okay. It's still too damn cold out anyway. I'll be ready for that first nice warm day.
Thanks, yes I just meant Poli-Seal.
Clean, Polish, & Seal with Poli-SealTM All-in-One
Optimum Poli-SealTM is the most remarkable, all-in-one product ever produced! This zero dusting, buttery-smooth formula is the ultimate, one-step product. It creates gloss and long term protection that is second to none. Optimum Poli-SealTM contains micro abrasives that eliminate (not hide) minor surface imperfections. It provides swirl mark removal, the final polish and a durable wax/sealant…all in one step! Poli-SealTM creates a perfect shine on all types of paint, fiberglass, gel coat and smooth molded plastic. A single application provides "optimum" protection for your vehicle that lasts for months!
Directions for use: Hand Application Apply to a small area with a dampened foam or cloth applicator. After slight hazing occurs, wipe-off with a microfiber or terry towel for a perfect shine. Machine Application Apply with orbital or rotary polisher and appropriate pad for the job. Apply just enough product to create a lubricating barrier between the buffing pad and the surface. Work across the area until product disappears. (We suggest 1000-1400 rpms for rotary polishers). Wipe with a lightly misted cotton towel for a steak-free, perfect finish. For more serious surface imperfections, use Optimum Polish or Optimum Compound prior to Poli-Seal.
Old Mar 23, 2009 | 10:23 PM
1badstx's Avatar
PoliSeal is great stuff. I run it on a megs polishing or finishing pad at 5.5
Old Mar 23, 2009 | 10:25 PM
c_ulater's Avatar
Kool. I'd like to get one this year.
Old Mar 24, 2009 | 08:45 AM
05supercrew's Avatar
Congrats. a DA is a must have. Now building your supply lol.
Old Mar 24, 2009 | 08:48 AM
I have a brand new (used once) Klasse kit if anyone wants it. Too much work, and it's finicky to apply.
Old Mar 24, 2009 | 09:20 AM
Buy some Poorboys products super easy to apply and remove.
Old Apr 8, 2009 | 05:16 PM
My PC finally arrived, but I have a question.
There's a 5" spacer on it now but it also came with a 6" spacer. I ordered the Lake Country 5" Backing Plate with 6.5" CCS pads. Should I switch to the 6", or just leave the 5" spacer on it?
Old Apr 8, 2009 | 06:20 PM
hwm3's Avatar
It's not a spacer, it's a counterweight. You're gonna want to run the 6" counterweight with the 6.5" pads.
Don't lose the 5" counterweight though. After you get the hang of things you might want to try some of the smaller pads.
Old Apr 8, 2009 | 06:40 PM
Oh, ok thanks. In the manual it shows it as a spacer and it says "A spacer is supplied with the 7336SP and 7424 to allow the backup pad to clear the eccentric plate screws." It looks like the arrow is pointing to the counterweight but they're calling it a spacer? Might just be the way the manual is showing it.
It does clearly say on each counterweight "use 5 inch pad only" or "use 6 inch pad only". I figured I'd ask some of you experienced folks instead.
Thanks for the reply.
Old Apr 10, 2009 | 03:07 AM
Old Dogg™'s Avatar
Make sure you experiment with smaller pads like 5.5" and 4".
You are going to love the decrease in work and increase in shine.
Good Luck.
Old Apr 15, 2009 | 09:09 AM
Smokey14's Avatar
I'm in Manitoba and looking to get a PW polisher as well. Where did you order yours? Finding a dealer in Canada is difficult at best.
Old Apr 15, 2009 | 10:12 AM
esf's Avatar
esf
PW?
eShine is located in Canada. They sell the PC 7424 and they have two Flex models though I don't know anything about either one of them. I believe atleast one of them is a rotary. Maybe both. I didn't really look at them.
