What to use to clean your tires?
Old Mar 22, 2009 | 09:30 AM
BEW119's Avatar
APC+ is great, also brings out the owl on the tires.
Old Mar 22, 2009 | 01:08 PM
mcr1994's Avatar
westleys bleche white and this brush do wonders http://www.autopia-carcare.com/cr-92018.html
Old Mar 22, 2009 | 04:26 PM
1lohauler's Avatar
If you have custom wheels other than FORD wheels be VERY careful when using Mean Green and Simple Green because it will strip off the clearcoat from the wheel or it will etch them if left on the wheel for a short time. Hope this helps out I normally use Mean Green or Simple Green and a firm brush and no browning also no tire shine of any kind
Old Mar 22, 2009 | 05:59 PM
pmason718's Avatar
Originally Posted by esf
A lot of people use Simple Green. I never have. I've always used an APC of some kind. Currently I'm using Meg's APC+ diluted 4:1 and a stiff brush to scrub it. Works like a champ. I use Meg's Hperdressing at 4:1 as a dressing for them. If I don't have any HD on hand I will use Stoner's More Shine. That stuff is awesome.
I need to get a brush for mine. Do you have a pic of what yours look like? Better yet, where did you get it from?
PS I have to upload pics from the class and the fest
Old Mar 22, 2009 | 06:04 PM
esf's Avatar
esf
I had gotten mine when I was on my Adam's kick. They don't even off it anymore. It's probably not the best brush but it works for me so I don't see a need to get a new one right now. As long as it has stiff nylon bristles you should be good. Mine has a pretty long handle as well so I Can get in the fender wells easy.
Old Mar 22, 2009 | 08:19 PM
Blang's Avatar
I have been looking into buying Meguiars APC. I found two types APC Green and APC Plus purple. Which do you guys prefer?
Old Mar 22, 2009 | 08:26 PM
esf's Avatar
esf
APC+ is orange. APC+ was designed to be low foaming so it could be used in carpet cleaners and extractors. That's what the + stands for. I don't know if it's any stronger though.
Old Mar 22, 2009 | 09:16 PM
FF/PM_L1563's Avatar
Originally Posted by Jolly_Green_Giant
I did for a long time. But don't do it when the wheel is hot and don't let it dry on the wheel. If you do it'll etch the wheel.
Absolutely correct advice.
A lot of times f you have used a dressing on your tires, tire wet, etc. and you stop using dressing the tires will turn brown. If a brish does not work then use a large smooth stone to remove. Works great and free of cost.
Old Mar 22, 2009 | 09:31 PM
Walmart has tire brushes that work fine. This is not a boutique item like some of the stuff you guys insist on using. It just isn't critical.
Old Mar 22, 2009 | 09:56 PM
Rockpick's Avatar
Moderator &
Sorry, Blang... missed this the first pass...
What ESF has stated is EXACTLY what I do on my vehicle as well as all of my client vehicles (minus a few special circumstances which will get a more 'aggressive' cleaning).
-RP-
Old Mar 23, 2009 | 12:32 AM
Blang's Avatar
Hey Rockpick do you prefer just APC or APC+? What do you use for an aggressive cleaning?
Old Mar 23, 2009 | 03:07 PM
If you need an aggressive tire cleaning, Westley's is exactly that. Protect your wheels if you use it.
Old Mar 23, 2009 | 08:42 PM
4wd150's Avatar
used simple green yesterday, it cleaned up my tires and wheel wells pretty good. all i did was rinse tire, spray SG on and scrub then rinse off. looks good
Old Mar 23, 2009 | 09:21 PM
last5oh_302's Avatar
I use Simple Green for A LOT of things, but to get rid of that brown film (caused by brake dust) and bring the white letters back to new, Spray 9 and a brush does the best job of anything I've tried. I was skeptical when I was told to try it a few years back, but now it's all I use for this purpose. It takes about 1 minute a tire. Spray it on and immediately start scrubbing the entire sidewall and then immdediately hose it off. Brand new tires baby, and white lettering that makes the tires look like brand new! They come out so clean I don't even bother with tire dressing half the time.
Old Mar 24, 2009 | 10:16 AM
diggman08's Avatar
i use Purple Power from advanced auto. , with No scrubbing... let it soak a few minutes then hit it with the pressure washer,,, makes em look brand new.. and i never use any tire shine of any kind.
