#7 dissappointed me...
Old Oct 1, 2008 | 08:23 PM
SlammaJamma's Avatar
I tried #7 for the first time this weekend on my truck and I saw no difference? Did I do something wrong or what? Used my DA as usual. I thought it would have given me some more "pop" at least.
Old Oct 1, 2008 | 08:29 PM
Rockpick's Avatar
Moderator &
What one will typically notice with #7 on a dark colored truck like yours is that it will deepen and darken the finish a tad. While it's not a spectacular transformation typically, most will note some improvements in overall look.
Can you give us a bit of your methodology and such?
Old Oct 1, 2008 | 09:34 PM
milkthegoat's Avatar
You really dont even need to use the DA. Try this
Wash
clay
80 (whatever you use if your doing this step)
7
nxt
26
Old Oct 1, 2008 | 09:57 PM
hwm3's Avatar
Wash
clay
7
nxt
26
Why would you not use the DA if you have one?
Old Oct 1, 2008 | 10:19 PM
Lumadar's Avatar
#7 is really intended for a single stage paint to be impressive. You're putting it on clearcoat...how much can it really do? There is a reason that 99.9% of people could not see ANY difference between a fresh coat of ANY coat of wax on the same paint.
That said, I tried #7 and thought it did nothing on my red, clearcoated finish. I did half the hood, and called it a day. the next day I parked my car in the sun and as I walked away I froze because something caught my eye. There was a distinct line up the middle of the hood and one half was definitely darker than the other.
It does something, just don't expect miracles on clear coats.
Old Oct 2, 2008 | 11:18 PM
I just wanted to try it because I see everyone using it. I used a w8006 pad, put DA on speed 1 to spread product as usual, kicked it up to 5 and worked it in. Removed with a MF and kept goin.
Another question...How does #80 compare to #2 as far as removal goes? I love the results of #2 but my paint isnt in bad shape so I don't usually need that much cut, plus it's difficult to remove at times.
Old Oct 6, 2008 | 11:17 PM
OnAF150High's Avatar
SlammaJamma,
7 is what Meguiars terms a pure polish meaning it has no defect removal abilities, and will add oils to the paint to help freshen up old single stage paint. When working it with a pc try using a 9006 finishing pad and use speed 3 for application not 5. Also try and remove it before it dries for easier removal. 7 is for single stage paint since I am sure you have clear coat paint you could try 81 hand polish and apply by hand or use the pc the same way that I just described above doing one panel at a time.
To answer your second question I will try my best. I have no experience with 2 but 80 and 2 are designed for different types of paint. 80 for clear and 2 for single stage. They use different types of abrasives in each. 2 if you put some in your hand you could feel a bit of grittiness to it while 80 has more of a hand lotion feel to it. 80 use diminishing abrasives and 2 uses more of a traditional non-diminishing abrasive. When to paint is properly prepped (washed and clayed) it removes very easy with a micro fiber or 100% terry towel. 80 also has the same trade secret oils as 7 so after 80 is used you may or may not need to use 7 or 81 after it. I hope I was able to help you out.
Andrew
