claying wheels?
Old Aug 3, 2008 | 07:47 PM
04f150stx's Avatar
claying wheels?
Is it safe to clay the wheels; Forte F7 Klutch, Black? Just want to make sure before I do it in the next couple of days. And if anyone is wondering why, it is because paint overspray got on them and that is the only why I know of to get it off.
Old Aug 3, 2008 | 08:05 PM
azmidget91's Avatar
worth a try, alot of people will probably tell you to throw it away after using on your wheels though
Old Aug 3, 2008 | 08:23 PM
ThumperMX113's Avatar
Yes, use the clay. I'd use it on your windows first and than the wheels, and than toss it.
Old Aug 3, 2008 | 10:50 PM
04f150stx's Avatar
Do I need to buy special wax to use on the wheels afterwards, or just use regular wax like I would use on the body?
And yes I do plan on throwing it away after I get the wheels done, glass is already done using 0000 grade steel wool.
Old Aug 3, 2008 | 10:59 PM
A sealant like NXT or Poorboy's Wheel Sealant. Nothing canuba based, it won't hold up to the heat.
Old Aug 4, 2008 | 11:29 AM
pmason718's Avatar
When using clay on the windows what are you guys using to lubricate the window. Are you using some type of QD like for the paint or a window cleaner?
Old Aug 4, 2008 | 01:38 PM
x_sgs_x's Avatar
Yea clay should work, i think you can use the lubracant it comes with and then clean with window cleaner.
Old Aug 4, 2008 | 02:20 PM
Use the same stuff you use on your paint. Than follow up with a window cleaner like Stoner's Invisble Glass.
Old Aug 6, 2008 | 10:39 AM
pmason718's Avatar
I love Invisible glass
