Tire Detailing
Tire Detailing
What do you guys do to detail your tires? I have something stained on my tires that is brown in color??? I dont know what it is. I wash them and when they are wet they look fine but as soon as they dry they still have the brown residue on them. I think it might be brake dust?...
Its hard to get every nook and cranny in my tire too because I have the nitto mud grapplers and they have a aggressive sidewall. I dont use any special tire cleaner on my tires when i was it, just normal soap that i use on the truck. Am I going to need to buy some tire cleaner to fix this or what? I want them nice and black and shiny!!
if you want some over the counter stuff, invest in some simple green. It works good with a stiff brush.
If you really want a good cleaner.. Meg's All Purpose Cleaner Plus, but unless you have a distributer near by you'll have to order that.
Hope that helps bro.
That brown that comes out is called blooming. It is the antiozonants in the tire. To get rid of that, you just have to keep cleaning them. A really good OTC tire cleaner that helps a lot with this is Eagle One A2Z Wheel and Tire Cleaner and a brush. You also have the option of an APC. If you use an APC, just make sure you dilute it accordingly. Using tire dressing is a plus too.
Also, pick up some Hyper Dressing by Meguiar's and apply it at a 4:1~ ratio. It will fix the brown and give you protection and shine.
www.autodetailingsolutions.com
First, get a pretty aggressive tire and wheel cleaner (like Eagle One). Follow the directions, and use a good stiff brush to get into all those nooks and crannies. If necessary, apply a second application of the T & W cleaner. Don't forget to RINSE thoroughly.
Next, get a brass brush made for RWL tires. Using a good APC, scrub the areas that have scuff marks to remove them and rinse.
Lastly, use your APC and your regular tire brush to go over the tire again, and again rinse thoroughly.
It probably takes me about 15 minutes per tire/wheel on my personal vehicles when I'm really "going after them".
As for dressing, it's a personal choice. They all seem to work better, and last longer when the tires are properly prepped.
HTH
Spray Nine and a brush brings them right back to new, It works wonders on white lettering as well. Just make sure you pressure hose it off right away.
Spray Nine does such a good job, I often don't even bother with a tire dressing afterwards, although it doesn't make the sidewalls shine, but it does make the tire look like new again.
APC - All Purpose Cleaner by Meguiars
I've always heard that a brown cast on the tires comes from a lack of protection from the sun and elements (but I doubt that it is the case looking at your truck). Does it have the same appearance as if the tire were curbed?
here is a picture and a little more about blooming:
http://www.meguiars.com/faq/index.cf...ection=_59#_59
When I've got a tire that has been subjected to blooming, I'll spray it down with water. Spray it down with a good APC, like Meguiars APC+ or Simgle Green. I prefer Meguiars APC+ as it is one of my favorite products by far. APC stands for All Purpose Cleaner and the "+" in Meguiars APC+ stands for the ability to be used on carpets as well as everything else. Let the APC sit on the tire for about 30 secounds before starting to scrub it with a stiff bristled brush with soap and water. This should clean the "brown" right off of the tire but remember it will strip any wax that you have put on your wheel so they will have to be re-waxed.
Also keep this in mind. Keeping the "brown" off of your tire is all about maintenance. Wash your tires every time you wash your vehicle with soap and water. I only use a dedicated tire mitt to clean my wheel. If you're still getting blooming that means you're not washing your vehicle often enough.
Good link.
Everyone's suggestions in here are great and I recommend to try probably some simple green or APC (All purpose cleaner) with a hard bristled brush. However this is something that no one has mentioned yet. Be VERY careful as to not get any of the cleaners on your paint. If it does, it will take off all of your wax in that area. If it does get on you will just have to reapply your wax.
It is likely that some cleaner will get on your wheels, so I would suggest waxing them when you are done!
PS: Is my sig too big?
