Help Requested with Poorboy's Order
Old Jun 2, 2008 | 01:24 PM
Val3ntin0's Avatar
I'm looking to place an order with Poorboys but I could use some help. It's a small one consisting of:
PB Black Hole
PB Wheel Sealant
PB EX-P
However, I have a few questions regarding these. My usual order of detailing the truck is:
Gold Wash
Clay
Meg's Step 1 & 2
NXT 2.0
With these additional products, where do they fit into my routine (excluding the wheel sealant)? Is EX-P and Black Hole a one or another scenario after the NXT 2.0?
Also, any other products from Poorboy's you'd recommend?
Old Jun 2, 2008 | 01:36 PM
hwm3's Avatar
PB Black Hole
PB Wheel Sealant
PB EX-P
Gold Wash
Clay
Meg's Step 1 & 2
NXT 2.0
Are you applying by hand or DA?
You can use both EX-P and Black Hole. EX-P is a sealant, Black Hole is a glaze, so apply Black Hole then EX-P. No need to follow EX-P with NXT, but you can top with a carnuba if you'd like.
Old Jun 2, 2008 | 01:54 PM
Val3ntin0's Avatar
At the moment everything is by hand....
Old Jun 2, 2008 | 04:59 PM
ThumperMX113's Avatar
Follow what hwm3 says and you'll be on your way. Black Hole is an awesome product, you'll love it !!
Old Jun 2, 2008 | 05:07 PM
Val3ntin0's Avatar
As the EX-P is a sealant, should I apply the NXT 2.0 followed by the Black Hole and topped with the EX-P?
Old Jun 2, 2008 | 05:34 PM
Wait 12 hours after applying the sealant to put on the NXT.
Old Jun 2, 2008 | 05:40 PM
RollingRock's Avatar
sorry did i miss something?
Why put NXT over EX-P?
Why wait 12 hours after EX-P? Can be topped in as little as 45-60 min.
Old Jun 2, 2008 | 05:46 PM
attworth's Avatar
Agree completely.
Old Jun 2, 2008 | 05:49 PM
05_sprcrw's Avatar
Right you can top ex-p in as little as an hour, I think he ment to wait 12 hours in between coats of nxt, or if you are going to top it with something else.
Old Jun 2, 2008 | 05:50 PM
attworth's Avatar
Originally Posted by 05_sprcrw
Right you can top ex-p in as little as 45 minutes, but an hour is preferred, I think he ment to wait 12 hours in between coats of nxt, or if you are going to top it with something else.
Old Jun 2, 2008 | 05:51 PM
Val3ntin0's Avatar
Now I'm all confused...
So it's Black Hole, Sealant, then NXT?
Old Jun 2, 2008 | 05:55 PM
attworth's Avatar
I don't know that you'd need NXT to top off the EX-P. EX-P is pretty protective already. I usually use Collinite 845 which looks nice and lasts a good while. You can also use something like the Natty's line of waxes, or something else for nice "pop."
Edit:
Just took the time to actually read the whole thread - my apologies.
I would do this:
Wash
Clay
Megs 1 and 2
Black Hole
EX-P (wait an hour, longer is not necessary...)
Top with the LSP of your choice.
Now, LSP - if you want to use NXT, go for it. I just don't find the extra protection necessary as per my prior comment. EX-P does a fine job sealing everything up. Unless you live in an area where you think you need it, i.e. lots of sand, lots of water, lots of salt, etc. I use Collinite 845 because here in TX we get a lot of wind and it tends to kick up all the dust and pollen and move it across my paint faster than I'd like. If I didn't have Collinite, I would probably use NXT.
If I didn't worry about the wind so much, I would pick up some Natty's Red, if you can find it (great for dark colors.) There's also a blue (dark colors,) and the regular which is white, (light colors/metallics.)
Use the wheel sealant whenever you feel like doing the wheels - might as well do it while you're doing the rest of the truck.
Good luck and have fun.
Old Jun 2, 2008 | 06:06 PM
Sorry, I was confused. I thought what I had been using was EX-P but it's EX. The guys at PB told me to wait 12 hours before applying anything over it.
Old Jun 2, 2008 | 06:13 PM
attworth's Avatar
I guess longer can't hurt but I don't think it'd make a huge difference..
Originally Posted by Specialty Motoring, per PB's Bottle
..Allow it to dry for thirty minutes and buff off. Humid conditions may extend the drying period. You can apply a second coat right away or wait 12-24 hours.
I believe the only reason to wait is to allow the Carnauba to "cure." (Remember the EX has Carnauba in it, EX-P does not..)
Old Jun 2, 2008 | 06:36 PM
Devildog101's Avatar
What you have here is correct. But what some others are trying to say is that you may not need the NXT step at all. NXT is a synthetic sealant even though many use it as their LSP (Last Step Product). You would be topping a sealant with a sealant. Maybe a little overkill. Like others have mentioned, if you go that route, you will not need to wait more than an hour before topping the EX-P.
Let me know how you like the Black Hole, I am putting it on my next order...
Hope this helped,
Devildog101
